I have this query and everytime it runs it is failing with this error failed to evaluate map function: unsupported binary expression invalid >= int From the context of the error it doesn’t like the value of my state_duration. I plugged my query into the explorer to make sure state_duration is coming back as a int and it is. The result in the table was -1. I can’t seem to understand what is wrong with my query. Any help would be great
import "influxdata/influxdb/monitor"
import "experimental"
import "influxdata/influxdb/v1"
option task = {name: "node-status-notready-task", every: 1m, offset: 10s}
check = {
_check_id: "",
_check_name: "Node-notready-task",
_type: "custom",
tags: {owner: "team-sre"},
every: 2m,
warn = (r) => r.state_duration >= 5 and r.state_duration <= 14
crit = (r) =>
(r.state_duration >= 15)
messageFn = (r) =>
("Threshold: ${r._check_name} is: ${r._level}
env:${r.env} | ns: ${r.namespace} | pod:${r.pod} | node:${r.nodename}
This indicates that node:${r.nodename} has not been ready for ${string(v: r.state_duration)}.
This should be investigated and documented here http://docs.internal/operations/specifications/runbooks/node-status-notready/:
data = from(bucket: "infra")
|> range(start: duration(v: int(v: task.every) * (-1)))
|> filter(fn: (r) =>
(r._measurement == "kube_node_status_condition"))
|> filter(fn: (r) =>
(r.condition != "Ready"))
|> stateDuration(fn: (r) =>
(r._status =~ /true|unknown/), unit: 1m, column: "state_duration")
data
|> v1.fieldsAsCols()
|> monitor.check(data: check, messageFn: messageFn, crit: crit, warn: warn)
