Internal Server Error when using filter in Flux
Im playing with Flux (influxdb 1.7) using Grafana.
When I type
from(bucket: "iobroker")
|> range(start: -5m)
I get the data displayed… so the connection works fine.
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,boolean,string,string
#group,false,false,true,true,false,false,true,true
#default,_result,
,result,table,_start,_stop,_time,_value,_field,_measurement
,0,2019-12-28T07:53:31.724972723Z,2019-12-28T07:58:31.724972723Z,2019-12-28T07:53:37.45Z,true,ack,mqtt.0.Stromzaehler_Aktuell
,0,2019-12-28T07:53:31.724972723Z,2019-12-28T07:58:31.724972723Z,2019-12-28T07:53:49.287Z,true,ack,mqtt.0.Stromzaehler_Aktuell
,0,2019-12-28T07:53:31.724972723Z,2019-12-28T07:58:31.724972723Z,2019-12-28T07:54:01.418Z,true,ack,mqtt.0.Stromzaehler_Aktuell
But when Im starting to use any filter function, for example
|> filter(fn: (r) => r["_measurement"] == "mqtt.0.Stromzaehler_Aktuell")
|> range(start: -5m)
I get “InfluxDB Error: Internal Server Error”.
This is the Json-Error-Object:
message:"InfluxDB Error: Internal Server Error"
data:Object
error:"Internal Server Error"
response:"error "error in building plan while starting program: cannot submit unbounded read to ""iobroker""; try bounding 'from' with a call to 'range'" "
message:"Internal Server Error"
config:Object
method:"POST"
url:"api/datasources/proxy/5/flux/api/v2/query?org=undefined"
params:Object
data:"from(bucket: "iobroker") |> filter(fn: (r) => r["_measurement"] == "mqtt.0.Stromzaehler_Aktuell") |> range(start: -5m) "
precision:"ms"
Any ideas what I did wrong???
Hi there:
I changed the name of the measurement to names without dots!
For example mqtt.0.Stromzaehler_Aktuell to StromzaehlerAktuell.
Now it works.
