InfluxDB 1.8: Getting ApiException using influxdb_client and Python
Hello Guys
I used to query my influxdb data using Python, the influxdb library and DataFrameClient. The Python API states to use the newer (influxdb-client) for v1.8+ and v2. As we are running Influxdb v1.8.1 I decided to switch to the influxdb-client and rework my Jupyter Notebooks. So I enabled Flux and tried to query the data using Pandas DataFrames (with the help of DataFrame and Flux examples). Using
from influxdb_client import InfluxDBClient, Point, Dialect
from influxdb_client.client.write_api import SYNCHRONOUS
client = InfluxDBClient(url="http://localhost:8086", token="username:password")
query_api = client.query_api()
df = query_api.query_data_frame('from(bucket:"MyDatabase/autogen") '
                                    '|> range(start: 2020-08-25T00:00:00Z, stop:2020-08-25T01:00:00Z)'
                                    '|> filter(fn: (r) => r._measurement == "MyMeasurement" and r._field == "MyColumn"')
I get the following Error:
ApiException: (500)
Reason: Internal Server Error
HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json', 'Request-Id': 'ba3e82d7-f0ef-11ea-8b7e-00155d6fb6df', 'X-Influxdb-Build': 'OSS', 'X-Influxdb-Error': 'loc 1:103-1:187: expected RPAREN, got EOF', 'X-Influxdb-Version': '1.8.1', 'X-Request-Id': 'ba3e82d7-f0ef-11ea-8b7e-00155d6fb6df', 'Date': 'Mon, 07 Sep 2020 09:51:40 GMT', 'Content-Length': '54'})
HTTP response body: b'{"error":"loc 1:103-1:187: expected RPAREN, got EOF"}\n'
Leaving out the filter I get a response of a List with several tables but not the desired Information for the Measurement. Moreover I’m using “database/retention policy” for the bucket and “username:password” for the authentification token as stated for the v1.8/v2 compatibility. I also tried to add the |> yield() -Statement but without success, still the same error.
Does someone know how to use the Flux filter properly regarding influxdb-client and Python? Do we have to switch to Influxdb v2?
I’m running Python 3.7.4, InfluxDB 1.8.1, influxdb-client 1.10.0 and pandas 1.0.3 on Windows 10.
Thanks in advance.
You’re just missing the close paren for the filter method inside the flux query (very end of your query).
Thanks a lot. The struggle with this small mistake was real :sweat_smile:
One more thing:
Why is the DataFrameClient of influxdb and its
client.query("SELECT MyColumn FROM MyMeasurement where time >= '2020-08-25 00:00:00' and time <'2020-08-25 01:00:00'")
much faster than the InfluxDBClient of influxdb_client and the
query_api().query_data_frame('from(bucket:"MyDatabase/autogen")
                        '|> filter(fn: (r) => r._measurement == "MyMeasurement" and r._field == "MyColumn")')
