Good evening,
I am currently trying to build a Docker Compose Stack with Grafana, InfluxDB and Telegraf. For testing purposes, a colleague wrote me a simple Pyhton OPC UA server that should output some data. Unfortunately, I keep getting the following error when I check the telegraf logs:
telegraf | 2025-07-07T16:46:10Z E! [inputs.opcua] Error in plugin: connect failed: dial tcp 192.168.65.254:5215: connect: connection refused
I have already created a rule in the firewall and allowed the connection to the port… Unfortunately, that didn’t help. And therefore no data arrives in InfluxDB…
Here is my telegraf.conf:
[agent]
interval = "10s"
round_interval = true
[[inputs.opcua]]
endpoint = "opc.tcp://host.docker.internal:5215/"
nodes = [
{ name = "hp_pressure", namespace = "2", identifier_type = "s", identifier = "hp_p" },
{ name = "hp_pressure_up", namespace = "2", identifier_type = "s", identifier = "hp_p_up" },
{ name = "hp_pressure_lo", namespace = "2", identifier_type = "s", identifier = "hp_p_lo" },
{ name = "fuel_pressure", namespace = "2", identifier_type = "s", identifier = "f_p" },
{ name = "fuel_pressure_up", namespace = "2", identifier_type = "s", identifier = "f_p_up" },
{ name = "fuel_pressure_lo", namespace = "2", identifier_type = "s", identifier = "f_p_lo" },
{ name = "lox_pressure", namespace = "2", identifier_type = "s", identifier = "lox_p" },
{ name = "lox_pressure_up", namespace = "2", identifier_type = "s", identifier = "lox_p_up" },
{ name = "lox_pressure_lo", namespace = "2", identifier_type = "s", identifier = "lox_p_lo" }
[[outputs.influxdb_v2]]
urls = ["http://influxdb:8086"]
token = "Removed"
organization = "Removed"
bucket = "Removed"
Here the Server:
# This starts an OPCUA server with some nodes that generate data based on their names
import asyncio
import logging
import random
import math
from asyncua import Server, ua, Node
from asyncua.ua import AttributeIds, LocalizedText, DataValue, DataTypeDefinition
def idFromString(ns: int, id: str):
return f"ns={ns};s={id}"
async def main():
server = Server()
await server.init()
server.set_endpoint("opc.tcp://[::]:5215/")
idx = await server.register_namespace("WARR")
obj_mcs = await server.nodes.objects.add_object(idFromString(idx, "mcs"), "mcs")
obj_systems = await obj_mcs.add_object(idFromString(idx, "sys"), "systems")
obj_hp = await obj_systems.add_object(idFromString(idx, "hp"), "high_pressure")
obj_fuel = await obj_systems.add_object(idFromString(idx, "f"), "fuel")
obj_lox = await obj_systems.add_object(idFromString(idx, "lox"), "liquid_oxygen")
await obj_hp.add_variable(idFromString(idx, "hp_p"), "hp_pressure", 250.0)
await obj_hp.add_variable(idFromString(idx, "hp_p_up"), "hp_pressure_up", 310.0)
await obj_hp.add_variable(idFromString(idx, "hp_p_lo"), "hp_pressure_lo", 0.0)
await obj_lox.add_variable(idFromString(idx, "lox_p"), "lox_pressure", 10.0)
await obj_lox.add_variable(idFromString(idx, "lox_p_up"), "lox_pressure_up", 60.0)
await obj_lox.add_variable(idFromString(idx, "lox_p_lo"), "lox_pressure_lo", 0.0)
await obj_fuel.add_variable(idFromString(idx, "f_p"), "fuel_pressure", 15.0)
await obj_fuel.add_variable(idFromString(idx, "f_p_up"), "fuel_pressure_up", 60.0)
await obj_fuel.add_variable(idFromString(idx, "f_p_lo"), "fuel_pressure_lo", 0.0)
async with server:
while True:
await asyncio.sleep(0.01)
if __name__ == "__main__":
asyncio.run(main(), debug=True)
I hope someone can help me ![]()
