Hello everybody,
I want to use influxDB with telegraf, but telegraf connection is refused by the influxDB.
My Story
Fundamentals:
- create a network:
docker network create --driver bridge influxdb-telegraf-net - create a volume:
docker volume create influxDBTelegraf
- First, I run my influxDB Container:
docker run -d --name=influxdb -p 8086:8086 -v influxDBTelegraf:/root/.influxdb2 --net=influxdb-telegraf-net influxdb
Then I setup the first parameters after localhost:8086 and named my bucket myfirstbucket.
After that, I configure my first CPU telegraf data source (see config file below). Additional, I download the .config and save the file as telegraf.config in…/Users/Programming/Documents/telegraf. You finde the telegraf.config in the appendix below.
Then I start telegraf:
docker pull telegrafdocker run --net=influxdb-telegraf-net -v $PWD/telegraf.conf:/etc/telegraf/telegraf.conf:ro telegraf
Now, all my container are running and I start to configure my APIToken and execute the following statements in the terminal of the telegraf container.
export INFLUX_TOKEN=NKt6_bvgkPwAkqkKdx_xeFI4EoB4mas0T6nx2BgZ7ieyE2HJTaelttZEPglS2p1CPyO0gnRUBHKvFy_Oyc8JjA==telegraf --config http://localhost:8086/api/v2/telegrafs/0af7bb2bbd6cc000
NOW, here comes my problem
2023-03-29T19:57:14Z I! Loading config url: http://localhost:8086/api/v2/telegrafs/0af7bb2bbd6cc000
2023-03-29T19:57:14Z E! error loading config file http://localhost:8086/api/v2/telegrafs/0af7bb2bbd6cc000: retry 0 of 3 failed connecting to HTTP config server: Get "http://localhost:8086/api/v2/telegrafs/0af7bb2bbd6cc000": dial tcp 127.0.0.1:8086: connect: connection refused
Why is the connection refused?
I hope you can help to find the error.
Thanks a lot.
With regards
Christian
Appendix
> # Configuration for telegraf agent
> [agent]
> ## Default data collection interval for all inputs
> interval = "10s"
> ## Rounds collection interval to 'interval'
> ## ie, if interval="10s" then always collect on :00, :10, :20, etc.
> round_interval = true
> ## Telegraf will send metrics to outputs in batches of at most
> ## metric_batch_size metrics.
> ## This controls the size of writes that Telegraf sends to output plugins.
> metric_batch_size = 1000
> ## Maximum number of unwritten metrics per output. Increasing this value
> ## allows for longer periods of output downtime without dropping metrics at the
> ## cost of higher maximum memory usage.
> metric_buffer_limit = 10000
> ## Collection jitter is used to jitter the collection by a random amount.
> ## Each plugin will sleep for a random time within jitter before collecting.
> ## This can be used to avoid many plugins querying things like sysfs at the
> ## same time, which can have a measurable effect on the system.
> collection_jitter = "0s"
> ## Default flushing interval for all outputs. Maximum flush_interval will be
> ## flush_interval + flush_jitter
> flush_interval = "10s"
> ## Jitter the flush interval by a random amount. This is primarily to avoid
> ## large write spikes for users running a large number of telegraf instances.
> ## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
> flush_jitter = "0s"
> ## By default or when set to "0s", precision will be set to the same
> ## timestamp order as the collection interval, with the maximum being 1s.
> ## ie, when interval = "10s", precision will be "1s"
> ## when interval = "250ms", precision will be "1ms"
> ## Precision will NOT be used for service inputs. It is up to each individual
> ## service input to set the timestamp at the appropriate precision.
> ## Valid time units are "ns", "us" (or "µs"), "ms", "s".
> precision = ""
> ## Log at debug level.
> # debug = false
> ## Log only error level messages.
> # quiet = false
> ## Log target controls the destination for logs and can be one of "file",
> ## "stderr" or, on Windows, "eventlog". When set to "file", the output file
> ## is determined by the "logfile" setting.
> # logtarget = "file"
> ## Name of the file to be logged to when using the "file" logtarget. If set to
> ## the empty string then logs are written to stderr.
> # logfile = ""
> ## The logfile will be rotated after the time interval specified. When set
> ## to 0 no time based rotation is performed. Logs are rotated only when
> ## written to, if there is no log activity rotation may be delayed.
> # logfile_rotation_interval = "0d"
> ## The logfile will be rotated when it becomes larger than the specified
> ## size. When set to 0 no size based rotation is performed.
> # logfile_rotation_max_size = "0MB"
> ## Maximum number of rotated archives to keep, any older logs are deleted.
> ## If set to -1, no archives are removed.
> # logfile_rotation_max_archives = 5
> ## Pick a timezone to use when logging or type 'local' for local time.
> ## Example: America/Chicago
> # log_with_timezone = ""
> ## Override default hostname, if empty use os.Hostname()
> hostname = ""
> ## If set to true, do no set the "host" tag in the telegraf agent.
> omit_hostname = false
> [[outputs.influxdb_v2]]
> ## The URLs of the InfluxDB cluster nodes.
> ## Multiple URLs can be specified for a single cluster, only ONE of the
> ## urls will be written to each interval.
> ## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
> urls = ["http://localhost:8086"]
> ## Token for authentication.
> token = "$INFLUX_TOKEN"
> ## Organization is the name of the organization you wish to write to; must exist.
> organization = "admin"
> ## Destination bucket to write into.
> bucket = "myfirstbucket"
> ## The value of this tag will be used to determine the bucket. If this
> ## tag is not set the 'bucket' option is used as the default.
> # bucket_tag = ""
> ## If true, the bucket tag will not be added to the metric.
> # exclude_bucket_tag = false
> ## Timeout for HTTP messages.
> # timeout = "5s"
> ## Additional HTTP headers
> # http_headers = {"X-Special-Header" = "Special-Value"}
> ## HTTP Proxy override, if unset values the standard proxy environment
> ## variables are consulted to determine which proxy, if any, should be used.
> # http_proxy = "http://corporate.proxy:3128"
> ## HTTP User-Agent
> # user_agent = "telegraf"
> ## Content-Encoding for write request body, can be set to "gzip" to
> ## compress body or "identity" to apply no encoding.
> # content_encoding = "gzip"
> ## Enable or disable uint support for writing uints influxdb 2.0.
> # influx_uint_support = false
> ## Optional TLS Config for use on HTTP connections.
> # tls_ca = "/etc/telegraf/ca.pem"
> # tls_cert = "/etc/telegraf/cert.pem"
> # tls_key = "/etc/telegraf/key.pem"
> ## Use TLS but skip chain & host verification
> # insecure_skip_verify = false
> # Read metrics about cpu usage
> [[inputs.cpu]]
> ## Whether to report per-cpu stats or not
> percpu = true
> ## Whether to report total system cpu stats or not
> totalcpu = true
> ## If true, collect raw CPU time metrics
> collect_cpu_time = false
> ## If true, compute and report the sum of all non-idle CPU states
> report_active = false
