Hello everyone,
Hello everyone,
I have set up Telegraf and InfluxDB in Docker containers and a simulation of a B&R PLC running on my host machine. I am trying to collect OPC UA data using the Telegraf OPC UA plugin.
Issue:
The connection to the OPC UA server appears to be working, as I receive an error message when I restart the PLC:
telegraf | 2025-03-13T05:29:50Z E! [inputs.opcua] Error in plugin: not connected, in state "Reconnecting"
telegraf | 2025-03-13T05:29:50Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
However, no data are written. After restarting the PLC, i got additional Errors from Telegraf:
telegraf | 2025-03-13T05:44:46Z E! [inputs.opcua] status not OK for node node1 (ns=6;s=::Program:stRtcTime.millisec): The node id refers to a node that does not exist in the server address space. StatusBadNodeIDUnknown (0x80340000)
The Telegraf Config for the OPC UA node as follows:
[[inputs.opcua.nodes]]
name = "node1"
namespace = "6"
identifier_type = "s"
identifier = "::Program:stRtcTime.millisec"
I also tried the workaround I’ve found, to wrap the identifier string with single quotes as mention by @R290 in this post, but it did not work either
identifier = '::"Program":"stRtcTime"."millisec"'
This results in
telegraf | 2025-03-13T05:44:50Z E! [inputs.opcua] status not OK for node node1 (ns=6;s=::"Program":"stRtcTime"."millisec"): The node id refers to a node that does not exist in the server address space. StatusBadNodeIDUnknown (0x80340000)
Next i tried to log to a datapoint with numeric identifier type:
name = "node2"
namespace = "0"
identifier_type = "i"
identifier = "2264"
This will not log any data but also not raise any error…
following the complete opcua configuration:
[[outputs.influxdb_v2]]
urls = ["http://influxdb:8086"]
token = "${DOCKER_INFLUXDB_INIT_ADMIN_TOKEN}"
organization = "${DOCKER_INFLUXDB_INIT_ORG}"
bucket = "${DOCKER_INFLUXDB_INIT_BUCKET}"
insecure_skip_verify = true
[outputs.influxdb_v2.tagpass]
source = ["PlcData"]
[[inputs.opcua]]
endpoint = "opc.tcp://host.docker.internal:4840"
connect_timeout = "10s"
request_timeout = "5s"
security_policy = "None"
security_mode = "None"
auth_method = "UserName"
username = "telegraf"
password = "1234"
name = "node1"
namespace = "6"
name = "node2"
namespace = "0"
identifier = "2264"
Any hints or suggestions are highly appreciated!
