I’m trying to restore single retention policy into Enterprise cluster from backup, which was made on InfluxDB OSS with -portable
option, version 1.5.2 is used in both OSS and Enterprise. Authentication is enabled in cluster and I confirm it works with both basic and JWT (internal-shared-secret
option is set):
influxd-ctl -auth-type jwt -secret mysecret show
Data Nodes
ID TCP Address Version
4 data-01:8088 1.5.2-c1.5.2
5 data-02:8088 1.5.2-c1.5.2
6 data-03:8088 1.5.2-c1.5.2
7 data-04:8088 1.5.2-c1.5.2
Meta Nodes
TCP Address Version
meta-01:8091 1.5.2-c1.5.2
meta-02:8091 1.5.2-c1.5.2
meta-03:8091 1.5.2-c1.5.2
Though when I try to restore a backup, I get "unable to parse authentication credentials"
error, which basically means influxd-ctl
command doesn’t see any credentials at all:
influxd-ctl -auth-type jwt -secret mysecret restore -db app_metrics -rp app_metrics_rp 20180531/app_metrics/by_rp/app_metrics_rp/
Using backup directory: 20180531/app_metrics/by_rp/app_metrics_rp/
Using meta backup: 20180531T070534Z.meta
Restoring meta data… 2018-05-31T16:52:24.893759Z info Meta client error {“log_id”: “08Pmg0i0002”, “error”: “unable to parse authentication credentials”, “retrying_after”: “20.000ms”}
2018-05-31T16:52:24.914387Z info Meta client error {“log_id”: “08Pmg0i0002”, “error”: “unable to parse authentication credentials”, “retrying_after”: “400.000ms”}
2018-05-31T16:52:25.315518Z info Meta client error {“log_id”: “08Pmg0i0002”, “error”: “unable to parse authentication credentials”, “retrying_after”: “3333.333ms”}
2018-05-31T16:52:28.649719Z info Meta client error {“log_id”: “08Pmg0i0002”, “error”: “unable to parse authentication credentials”, “retrying_after”: “3333.333ms”}
2018-05-31T16:52:31.983813Z info Meta client error {“log_id”: “08Pmg0i0002”, “error”: “unable to parse authentication credentials”, “retrying_after”: “3333.333ms”}
Error.
restore: operation timed out with error: unable to parse authentication credentials
I was able to make restore work only with disabled meta nodes authentication. When it’s enabled, all the commands work as expected (including backup
), but not restore
Is this a bug?
