Unable to backup data Auth error
I am getting the following error.
Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
I listed all the tokens using influx auth list and tried using them to do back up, but getting the same error.
The document says root authorization token should be used. I do not remember deleting any token after I had created the account.
Is there a way to generate root authorization token. I have the token of owner mentioned inside Web UI; have tried it but with same result. Is root token different from owner token?
Hello @shree,
Welcome!
What version of InfluxDB are you using? This should have been fixed.
Can you try regenerating a new all access token and trying again?
Hi @Anaisdg , I am having the same problem. I somehow deleted the token that was created during the upgrade from 1.8 to 2.6 . I created an all access token but get the same “unauthorized error” .
Anything I can do ?
thanks
I was able to solve this by using the command
influxd recovery auth create-operator
