Don't understanding how to return variable
Hi ! I’m new to Flux and I don’t understand how to return the value of a variable !
I read the doc Query using conditional logic in Flux | InfluxDB OSS 2.6 Documentation for the 0.5 Flux version and I want to return the hour value.
Here is my code, but I think it doesn’t work as well…
My code
transformHour = (number=<-) => {
     number
        |> hour:
            if number._value >= 60 then number._value / 60
            else if number._value >= 3600 then number._value / 3600
            else number._value
from(bucket: "test/autogen")
  |> range(start: dashboardTime)
  |> filter(fn: (r) => r._measurement == "my_measurement" and (r._field == "my_field"))
  |> count()
  |> transformHour()
This is what I obtain:
That’s not what I want.
The visualization mode is Single Stat.
I just would like to understand how to return hour value.
Thank you in advance
Nico
EDIT
I tried this code with a yield() funtion, but it seems not working.
	number
        |> hour:
            else number._value
   		||> yield(name: hour)
Where is the problem?
The UI can only visualise table data ATM. Instead, you will have better luck with the InfluxDB CLI.
influx repl should drop you into a shell :+1:
Hello @NicolasDrapier,
I believe you’re missing a map(). The following works for me:
from(bucket: "default")
  |> filter(fn: (r) => r._measurement == "cpu")
  |> filter(fn: (r) => r._field == "usage_system")
  |> filter(fn: (r) => r.cpu == "cpu-total")
  |> map(fn: (r) => ({
        output:
        if r._value >= 60.0 then r._value / 60.0
            else if r._value >= 3600.0 then r._value / 3600.0
            else r._value
This work from me !
Thank you so much
