Just having a play with Flux using InfluxDB v1.7.6 and can’t seam to get math to work
currently in Chronograf I have:
tbl_Pow_Wh = from(bucket: "dbDemo/1year")
|> range(start: dashboardTime)
|> filter(fn: (r) =>
r._measurement == "Demo" and
r._field == "value" and
r.Device == "House Load" and
r.Signal == "Watt" and
r.Equipment == "Main Board"
|> aggregateWindow(every: 15m, fn: sum)
|> map(fn: (r) => r._value * 1000))
and all I get is “[object Object]” in the data window. Without the map function I get data like:
| #datatype |
string |
long |
dateTime:RFC3339 |
dateTime:RFC3339 |
dateTime:RFC3339 |
string |
string |
string |
string |
string |
double |
| #group |
FALSE |
FALSE |
TRUE |
TRUE |
FALSE |
TRUE |
TRUE |
TRUE |
TRUE |
TRUE |
FALSE |
| #default |
_result |
| result |
table |
_start |
_stop |
_time |
Device |
Equipment |
Signal |
_field |
_measurement |
_value |
0 |
2019-05-09T03:42:05.140537091Z |
2019-05-10T03:42:05.140537091Z |
2019-05-09T03:45:00Z |
House Load |
Main Board |
Watt |
value |
Demo |
432.6 |
0 |
2019-05-09T04:00:00Z |
House Load |
Main Board |
Watt |
value |
Demo |
436.1 |
0 |
2019-05-09T04:15:00Z |
House Load |
Main Board |
Watt |
value |
Demo |
439.9 |
any help would be appreciated, thanks.
MarcV
2
Hi @Yendor welcome ,
Is the result without the map function ok ?
In the map function you have 2 )) at the end ,
You need only 1 )
Thanks @MarcV,
Yes the query returns data without the map function correctly.
I was tying a few combinations
|> map(fn: (r) => (r._value * 1000))
and left a typo in, even with the typo fixed I still get a error of
Error: type error 0:0-0:0: invalid record access "_value":int != float
after tying the following combinations finally got one to work
|> toFloat()
|> map(fn: (r) => r._value * 1000) # Error: Internal Server Error
|> map(fn: (r) => float(v: r._value) * float(v: 1000)) # Error: Internal Server Error
|> map(fn: (r) => float(v: r._value) * 1000.0) # Error: Internal Server Error
|> map(fn: (r) => float(v: r._value) * 1000.00) # Error: Internal Server Error
|> map(fn: (r) => r._value * float(v: 1000)) # Error: Internal Server Error
|> map(fn: (r) => r._value * 1000.0) # Error: Internal Server Error
|> map(fn: (r) => r._value * 1000.00) # Error: Internal Server Error
|> map(fn: (r) => ({_value: (r._value * 1000))}) # Error: type error 0:0-0:0: invalid record access "_value":int != float
and the working one
|> map(fn: (r) => ({_value: (r._value * 1000.00))})
then going back to
both where working, got me stumped. I guest its still a beta so there are some bugs.
aserkin
4
i was fighting with map few days with influxdb-1.7.7/chronograf-1.7.12. Finally on
influxdb-1.7.8/chronograf-1.7.14 the following construction works:
|> map(fn: (r) => ({_time: r._time, card: r.card, _value: r._value * 8.0 / 1073741824.0}))
this was to convert bytes to gigabits. Dramatically depends on version so far.
