I’m using InfluxDB 1.7.8 on Ubuntu 18.04.1 LTS which has fluxlang 0.36.2, according to the 1.7.8 release notes.
I’m trying to perform simple mathematics on my timestamps, as documented in the Duration Literals section of the Flux spec.
My Goal:
My goal is to calculate the energy supplied to some electrical loads, over the last 7 days, divided into 24 hour time windows.
Here is my query:
from(bucket: "my_bucket")
|> range(start: -7d)
|> filter(fn: (r) => r._measurement == "xxx_redacted_xxx" and r._field == "total_out_kwh")
|> aggregateWindow(every: 24h, fn: mean, createEmpty: false)
|> difference()
|> keep(columns: ["_time", "_value"])
which returns the following:
double dateTime:RFC3339
_value _time
0.249629482 2019-11-08T00:00:00Z
0.25453356 2019-11-09T00:00:00Z
0.264758042 2019-11-10T00:00:00Z
0.245200554 2019-11-11T00:00:00Z
0.190323976 2019-11-12T00:00:00Z
0.218066138 2019-11-13T00:00:00Z
0.202043946 2019-11-13T09:35:09.445884868Z
What this provides me with is the total energy produced in 24h time periods for the last 7 days. The problem lies in the timestamps. If you look at the first entry in the dataset above, the timestamp is 2019-11-08T00:00:00Z and it represents the 24 hour time period up to the beginning of, but not including the 8th of November 2019. To the end user then, this is actually the energy consumed during the 7th of November 2019.
My solution:
After bit of research I found in the Flux spec that it is possible to perform mathematical operations on timestamps by adding/subtracting durations. I tried adding the following map function to the end of my query above:
|> map(fn: (r) => ({
_time: r._time - 1d,
_value: r._value
which produces the following error:
Error: type error 0:0-0:0: invalid record access “_time”: duration != time
Please can anybody tell me why I’m getting this error?
Addendum: an extra prize for astute readers
Astute readers may have realised that my proposed solution works for all timestamps, except the last one. This timestamp represents the energy supplied to the electrical loads during the 13th of November. In other words:
- to: 2019-11-13T09:35:09.445884868Z
So that means I need to know when I’m dealing with the last row in my dataset and not subtract 1d from this timestamp.
Any ideas how I can find the index and length of my dataset?
