I wish to store variables that are automatically adapting to the time window my dashboard is set on. For example:
from(bucket: "BUCKET_NAME")
|> filter(fn: (r) => r._measurement == "hydraulic.oil.pressure")
|> pivot(valueColumn: "_value", rowKey: ["_time"], columnKey: ["_measurement"])
|> map(fn: (r) => ({
_time: r._time,
_value: r["hydraulic.oil.pressure"] > 40
This variable is a filter by value, and I want to rapidly know if I am with a positive non negligible value. But it seems the time range of the variable is not adapting to the time range of the query I use it in:
|> map(fn: (r) => ({
_time: r._time,
_value: if v.isOilPressureUp then r["rudder.rake.port.request"] / 1000.0 - r["rudder.port.rake"] / 4096.0 else 0.0,
Is this possible?
