I would like to calculate the ratio of two values, each returned by a subquery. If I execute them separately, the returned data looks good:
1st Query:
SELECT max(“value”)-min(“value”) AS verbrauch FROM StromzaehlerkWh WHERE time > now()-7d ;
┃ index ┃ time ┃ verbrauch ┃
┃ 1┃ 1681998913.0000000000┃ 8.8686000000┃
2nd Query:
SELECT max(“value”)-min(“value”) AS Einspeisung FROM “StromzaehlerEinspeisungkWh” WHERE time > now()-7d ;
┃ index ┃ time ┃ Einspeisung ┃
┃ 1┃ 1681998164.0000000000┃ 149.3115000000┃
But if i try to combine them together, I get a nil value
SELECT Einspeisung, Verbrauch FROM
(SELECT max(“value”)-min(“value”) as Verbrauch FROM StromzaehlerkWh WHERE time > now()-7d ) ,
(SELECT max(“value”)-min(“value”) AS Einspeisung FROM “StromzaehlerEinspeisungkWh” WHERE time > now()-7d );
┃ index ┃ time ┃ Einspeisung ┃ Verbrauch ┃
┃ 1┃ 1681998466.0000000000┃ 149.8254000000┃ <nil>┃
The result is also the same, if I put the WHERE clause to the outside select.
( SELECT max(“value”)-min(“value”) AS Verbrauch FROM StromzaehlerkWh ) ,
(SELECT max(“value”)-min(“value”) AS Einspeisung FROM “StromzaehlerEinspeisungkWh”)
┃ 1┃ 1681998779.0000000000┃ 150.2276000000┃ <nil>┃
Any hint, what I am doing wrong?
