Calculate ratio between tags
I just started implementing Influxdb with Grafana for our business KPIs. Is there any way to make calculation between tags on the same value?
My data looks like this:
data, type=valid value=10
data type=fraud value=3
I would like to get the Fraud/Valid ratio (0.3) in Grafana Single Stat.
Is there any option to do this or should I store the data in different format like fraud=3 and valid=10?
Thanks in advance.
Issue is Solved and data structure changed.
How did you solve it?
I am trying to find a way to calculate percent between to fields, maybe your solution can help me
I turned my tags to fields. So I can query them and calculate with subquery. TL;DR InfluxDB Tech Tips - All About the New Subqueries! | InfluxData
Original (normal query):
SELECT sum("field1") as "sum_field1", sum("field2") as "sum_field2" FROM ... WHERE ... GROUP BY ..
And then you can use it as a subquery:
SELECT "sum_field1" / "sum_field2" FROM ( SELECT sum("field1") as "sum_field1", sum("field2") as "sum_field2" FROM ... WHERE ... GROUP BY ... )
Thanks, will try tomorrow and get back
I now understand that my query is little bit more complicated.
I want to select data from a measurement then compare it with same measurement but where I have filtered out data that is between certain numbers.
data = all values
datafiltered = values between 10 and 100
SELECT "data" / "datafiltered" FROM
SELECT count("peak") AS "data"  FROM "autogen"."CPU" WHERE ("host" =~ /^$Host$/)  AND $timeFilter GROUP BY  "Host"
SELECT count("peak") AS "datafiltered" FROM "autogen"."CPU" WHERE ("host" =~ /^$SHost$/) AND ("peak"< 100 OR "peak">10) AND $timeFilter GROUP BY  "Host"
Does your query work for you?
I tried something similar but it doesn’t allow me to SELECT FROM two subqueries.
My query looks like this
SELECT (("exA_spread"+"exB_spread")/2 )
AS "average"
FROM(
	SELECT (("askPrice1" - "bidPrice1") * 200 / ("askPrice1" + "bidPrice1"))
	AS "exA_spread"
	FROM "three_month_data"."orderbook_exA"
	WHERE("instrument" = 'exA:btc_usdt') AND $timeFilter
	GROUP BY "instrument"  fill(previous)
	SELECT(("askPrice1" - "bidPrice1") * 200 / ("askPrice1" + "bidPrice1"))
	AS "exB_spread"
	FROM "three_month_data"."orderbook_exB"
	WHERE( "instrument" = 'exB:btc_usdt') AND $timeFilter
The two subqueries works fine by themselves alone as a query, but when I try to perform join-measurement as above, it seems grafana won’t let me to SELECT FROM two subqueries.
No it doesn’t work for me
