Dividing results of two sub-queries fails [InfluxDB 1.8.2]
So I need to divide two scalar values produced by two queries to a single measurement, and I came up with the following solution (I use Grafana for visualisation):
SELECT sum("errors") / sum("total") AS "errorPercentage" FROM (
  SELECT count("duration") AS "total" FROM "requests" WHERE [[timeFilter]]
  SELECT count("duration") AS "errors" FROM "requests" WHERE [[timeFilter]] AND "result" = 'KO'
As you may have guessed, a goal is simple, calculate error percentage for some of my custom requests data.
Each sub-query produces a valid result, but when combined like that they produce nothing.
A bit of debugging information:
If I query like this:
SELECT sum("errors") as "errors", sum("total") as "total" FROM (
A result looks like this:
Switching sub-queries produces a different result:
I can’t include more than one image sadly, but result is “errors” field has a valid value, when “total” is empty
Looks like issue is with the second sub-query.
But if I don’t use any aggregate functions on main query like this (sub-queries position is same as for initial variant):
SELECT "errors", "total" FROM (
The result is same as for previous query, where result is “errors” field has a valid value, when “total” is empty
Now second sub-query is calculated, but not the first one.
I’m a bit confused, may be someone will help me with this issue?
I think this might be something you could do with Kapacitor
hope that helps
Sadly, I need a pure influxql solution for this task. I’ve figured out a solution using Flux, but for the same reason I can’t use it in my situation.
I’ve seen it done before in the internet and tried to mimic the solution, but with no results.
Link to mentioned solution:
I believe you will want to use a “Transform”, create 2 Quieries then add 2 Transforms
Query 1:
Query 2:
Transform 1:
Outer Join: Time
Transform 2:
Binary Operation: errors / total
But, in my case this isn’t sufficient as I need to programmatically do a Binary Operation across tags. However, I just found that there is a “Group By” transform option in Grafana 7.2.
remove the count from inner subqueries and put it in outer one,
