Dear community,
I have been working on this query for more than a month now. Starting to feel crazy/stupid.
I am sure you can help me with this.
Basically, I am trying to access two entities from the same table and make operations on it.
My goal is to compute the percentage of electricity consumption cost of one device compared to the total cost.
Here is what I believe the final query should look like but it does not work:
SELECT meross_1/total AS result FROM (SELECT sum(max_meross_1) AS meross_1 FROM (SELECT max(value) AS max_meross_1 FROM homeassistant.autogen.EUR WHERE time > now() - 7d AND time < now() AND entity_id='meross_1_daily_cost' GROUP BY time(1d) FILL(null)), SELECT sum(max_total) AS total FROM (SELECT max(value) AS max_total FROM homeassistant.autogen.EUR WHERE time > now() - 7d AND time < now() AND entity_id='daily_cost' GROUP BY time(1d) FILL(null)))
Error is: Request failed with status code 400
However, if I simplify it, this works:
SELECT meross_1/meross_1 AS result FROM (SELECT sum(max_meross_1) AS meross_1 FROM (SELECT max(value) AS max_meross_1 FROM homeassistant.autogen.EUR WHERE time > now() - 7d AND time < now() AND entity_id='meross_1_daily_cost' GROUP BY time(1d) FILL(null)))
And this too:
SELECT total/total AS result FROM (SELECT sum(max_total) AS total FROM (SELECT max(value) AS max_total FROM homeassistant.autogen.EUR WHERE time > now() - 7d AND time < now() AND entity_id='daily_cost' GROUP BY time(1d) FILL(null)))
So I have been trying to super simplify my problem.
This works:
SELECT * FROM homeassistant.autogen.EUR, homeassistant.autogen.W
This does not work:
SELECT * FROM homeassistant.autogen.EUR WHERE EUR.entity_id='daily_cost' OR EUR.entity_id='meross_1_daily_cost'
Error is: Your query is syntactically correct but returned no results
As you can see, I am getting a bit lost decomposing my problem and trying to test bit after bit to make it work.
Thank you!
