I use grafana to monitor our system, and influxdb as datastore. I disabled Influxdb http logging in the config file:
[http]
# Determines whether HTTP endpoint is enabled.
# enabled = true
# The bind address used by the HTTP service.
# bind-address = ":8086"
# Determines whether HTTP authentication is enabled.
# auth-enabled = false
# The default realm sent back when issuing a basic auth challenge.
# realm = "InfluxDB"
# Determines whether HTTP request logging is enable.d
log-enabled = false
# Determines whether detailed write logging is enabled.
write-tracing = false
Restarted influxd service and I refresh grafana page, the logging was still shown in syslog
Mar 31 16:46:20 lknode53 influxd[11144]: [I] 2017-03-31T08:46:20Z SELECT last(used) / last(total) AS mem_used FROM telegraf.autogen.mem WHERE time > now() - 1h GROUP BY time(2s), host ORDER BY ASC service=query
Mar 31 16:46:40 lknode53 influxd[11144]: [I] 2017-03-31T08:46:40Z SELECT elapsed(last(system), 1s) FROM telegraf.autogen.erlang_memory WHERE time > now() - 5m GROUP BY time(200ms), * ORDER BY ASC service=query
Mar 31 16:47:01 lknode53 influxd[11144]: [I] 2017-03-31T08:47:01Z SELECT last(used) / last(total) AS usage FROM telegraf.autogen.disk WHERE time > now() - 1m GROUP BY time(50ms), host, path service=query
Mar 31 16:47:20 lknode53 influxd[11144]: [I] 2017-03-31T08:47:20Z SELECT elapsed(last(system), 1s) FROM telegraf.autogen.erlang_memory WHERE time > now() - 5m GROUP BY time(200ms), * ORDER BY ASC service=query
Mar 31 16:47:20 lknode53 influxd[11144]: [I] 2017-03-31T08:47:20Z SELECT last(used) / last(total) AS mem_used FROM telegraf.autogen.mem WHERE time > now() - 1h GROUP BY time(2s), host ORDER BY ASC service=query
What should I do to disable the logging or redirect the log to another file? Thanks
-Jack
