I have set up a DBRP mapping according to the Influx documentiation, but it appears that it is being ignored when I try to make a API query through curl as no data is being returned. Issue occurred with InfluxDB 2.0.4 running under docker on Debian 10.
Running the following on the Influx CLI:
influx v1 dbrp list -o spiro -t <token>
yields
ID Database Bucket ID Retention Policy Default Organization ID
0743c2ae30a58000 empc_demo b19272847848e4de autogen true bbf4fcb660e98f19
Querying the dbrp endpoint with the appropriate authorization header returns the expected response:
"content": {
"id": "0743c2ae30a58000",
"database": "empc_demo",
"retention_policy": "autogen",
"default": true,
"orgID": "bbf4fcb660e98f19",
"bucketID": "b19272847848e4de"
When I run a flux query through the Influx2 API with curl, such as:
curl --request POST http://127.0.0.1:8086/api/v2/query?org=spiro --header "Authorization: Token
<token>" --header 'Accept: application/csv' --header 'Content-type: application/vnd.flux' --data
"'import "influxdata/influxdb/schema'
schema.measurements(bucket: "empc_demo")" -v
I get a long list of measurements including:
,_result,0,task_scheduler_total_execute_failure
,_result,0,task_scheduler_total_execution_calls
,_result,0,task_scheduler_total_release_calls
,_result,0,task_scheduler_total_schedule_calls
,_result,0,task_scheduler_total_schedule_fails
,_result,0,variables_float
If I try to get the same information using the Influx QL endpoint as:
curl --request GET http://127.0.0.1:8086/query?org=spiro?database=empc_demo --header
"Authorization: Token <token>" --header "Accept: application/json" -v --data-urlencode "q=SHOW
MEASUREMENTS ON empc_demo"
the the response is just an empty json object i.e. {}.
Influx log shows:
ts=2021-03-23T15:42:19.078320Z lvl=info msg="executing new query" log_id=0T3eeSIG000 query=
I have tried a number of other queries and the behavior is always the same. Am I missing some step to “activate” the dbrp mapping?
