I am using ec2 instance on which i am running influxdb as docker container. Version of influxdb is 2.0, i want to query data using influxql. I have created the mapping of bucket required. Retention policy i mentioned was infinite.
Following is query i am using:
curl --request GET http://localhost:8086/query?db=db_name --header "Authorization: Token Token_id" --data-urlencode "q=SELECT * FROM db_name.measurement_name WHERE tag1=value1 AND tag2=value2 AND time >= '2022-06-06T07:00:00Z' AND time <= '2022-06-06T07:30:00Z'"
The output returned everytime is {}
I am sure that data is there for particular tag values and in that time duration by verifying in influxdb ui. Not sure what is the issue here. Can anyone help
