I am using a staging db to write data to influxdb. In the staging db it is written data which might also have time back in the past. I need to provide access to data (at database level) based on some criteria (e.g. data tagged with server=‘xyz’, can be accessed by user ‘user_xyz’). What is best way to achieve this?
One idea is to copy data from staging db to different final dbs and assign specific access to each final db. How can I copy data using e.g. Kapacitor (or continuous queries) also ensuring past data (data pushed now with a time of 1 year back) is also copied?
I found a way to do it with Kapacitor, but it doesn’t work in case I write old data:
batch
|query('SELECT mean(value) FROM "db_staging"."autogen"."temp"')
.period(1s)
.every(1s)
.groupBy(time(100ms), *)
|influxDBOut()
.database('db_final')
.measurement('temp')
and
kapacitor define move_data -type batch -tick b_test_back_data.tick -dbrp db_staging.autogen
kapacitor enable move_data
Is it there a way or triggering Kapacitor also on old data writing? Or…
Thanks,
Andrea
