Hey guys. I have a question about the working of kapacitor and its connection to influxDB
I have around 20,000 records in influxDB in a table called new_data ranging from 2019-12-03 to 2019-12-11
I created a kapacitor batch task that would yield me a day’s worth of data every hour
I can see that the batch task is created and is executing
I tried to ingest this “batched” data into a python script by querying the new_data table
However, I still get all 20,000 records when in reality I should be ingesting only about 1,000 records into the python script.
It would be great if someone can point out the mistake in my approach. I have tried to search for answers but I am really at a dead end. Any help is appreciated! Thanks in advance!
Hello @adityal2810,
I’m not sure, so I’m going to ask around. However, I would imagine that you need to save the batched data to a new database with a RP of 1 day if you’re hoping to only store 1 days worth of data. Can you please share your python script and also your TICK script?
var chunk = batch
|query(‘SELECT * FROM “dummydb”.“autogen”.new_data’)
.period(52w)
.every(15m)
|influxDBOut()
.create()
.database(‘dummydb’)
.retentionPolicy(‘autogen’)
.measurement(‘batch_data1’)
I am not able to create ‘batch_data1’ measurement in influxdb. Isn’t this the right approach? I included a groupBy clause and I was able to create a new measurement but it is not working the second time which is weird. Please advise!
