Use Kapacitor to export data into various databases
We have a central InfluxDB server which receives measurements from numerous hosts in our network. We want to export measurements from specific hosts to a customer database and tag that with a customer ID. For this I tried to write a number of TICK scripts to fix this in Kapacitor. However, I can’t get the script to work: although the script loads, no data is written to the target database.
This is one of many attempts to get this to work:
dbrp "telegraf"."autogen"
stream
    |from()
        .database('telegraf')
        .retentionPolicy('autogen')
        .measurement('jitsi_stats')
        .where(lambda: ("host" =~ '/customer-hostname/'))
        .groupBy(*)
    |influxDBOut()
        .cluster('writer')
        .database('customer')
        .retentionPolicy('retention_30d')
        .tag('customer_id', '12345')
If I try to query the Influx database, I get proper data:
> select bit_rate_download from "telegraf"."autogen".jitsi_stats where host =~ /customer-hostname/ and time > now() - 1m
time                 bit_rate_download
2020-07-13T09:45:39Z 0
2020-07-13T09:45:40Z 0
(etc)
Any hints on what I’m doing wrong and how to get this to work would be appreciated!
Turns out I forgot to add a correct subscription entry in my kapacitor config, so no data could be received. Now that I fixed that, everything works as designed.
