Hi everyone! I have a problem to connect Suricata with Telegraf, using unix_stream socket:
Host: Ubuntu 20.04
Docker: SURICATA_VERSION=6.0.6
Docker: INFLUXDB_VERSION=2.1.1
Docker: TELEGRAF_VERSION=1.21
Suricata confg:
- eve-log:
enabled: yes
filetype: unix_stream
filename: /var/run/suricata/suricata-command.socket
types:
- stats:
totals: no # stats for all threads merged together
threads: yes # per thread stats
Telegraf config:
# Suricata stats and alerts plugin
[[inputs.suricata]]
## Data sink for Suricata stats and alerts logs
# This is expected to be a filename of a
# unix socket to be created for listening.
source = "/tmp/suricata-command.socket"
# Delimiter for flattening field keys, e.g. subitem "alert" of "detect"
# becomes "detect_alert" when delimiter is "_".
delimiter = "_"
## Detect alert logs
# alerts = false
Suricata error:
25/7/2022 -- 09:56:27 - <Warning> - [ERRCODE: SC_ERR_SOCKET(200)] - Write error on Unix socket "/var/run/suricata/suricata-command.socket": Broken pipe; reconnecting...
25/7/2022 -- 09:56:27 - <Notice> - Reconnected socket "/var/run/suricata/suricata-command.socket"
25/7/2022 -- 09:56:27 - <Info> - Command server: client message is too long, disconnect him.
