- OPNsense 21.7-amd64
- os-telegraf 1.11.0 (Telegraf 1.19.0)
- InfluxDB 2.0.7
- Suricata version 5.0.7 RELEASE running in SYSTEM mode
Telegraf is not sending metrics to InfluxDBv2 related to [[inputs.suricata]]. I do not know why nothing is happening. All other metrics are OK (default System metrics; swap/cpu/disk/pf/etc). I was hoping I could skip Grafana and just use InfluxDBv2 dashboard functionality.
Steps to reproduce:
SSH into OPNsense box. As root,
service suricata stop&service telegraf stop. -
Edit
/usr/local/etc/telegraf.confand add:
[[inputs.suricata]]
## Data sink for Suricata stats log.
# This is expected to be a filename of a
# unix socket to be created for listening.
source = "/tmp/suricata-stats.sock"
# Delimiter for flattening field keys, e.g. subitem "alert" of "detect"
# becomes "detect_alert" when delimiter is "_".
delimiter = "_"
Using service telegraf start, a UNIX-socket has been created in the /tmp directory:
file /tmp/suricata-stats.sock
/tmp/suricata-stats.sock: socket
Suricata Fails to Create Socket - #2 by vjulien - Help - Suricata say that;
- suricata doesn’t create the unix socket, but instead if connects to an existing one.
Suricata is started as root, so there are no permission issues for the connection from suricata to this socket.
- Add a new eve-log output in
/usr/local/etc/suricata/suricata.yaml:
outputs:
- eve-log:
enabled: yes
filetype: unix_stream
filename: /tmp/suricata-stats.sock
types:
- stats:
threads: yes
- Issuing
service suricata startyields no error-messages:
Starting suricata.
26/7/2021 -- 23:28:33 - <Info> - Including configuration file installed_rules.yaml.
26/7/2021 -- 23:28:33 - <Info> - Configuration node 'rule-files' redefined.
26/7/2021 -- 23:28:33 - <Info> - Including configuration file custom.yaml.
However, there are no metrics populated in InfluxDBv2, and I do not know why. I do not know how to “sniff” in on a UNIX-socket and the size of the .sock always stays at 0B.
However, stopping telegraf and trying to create a UNIX-socket with the user telegraf sudo -u telegraf nc -U -l /tmp/suricata-stats.sock gives me a lot of data ("event_type":"stats"), so the stream is flowing.
Also verified by sockstat when using the telegraf service;
sockstat | grep suri
root suricata 93358 3 dgram -> /var/run/logpriv
root suricata 93358 4 stream -> /tmp/suricata-stats.sock
By the looks of it, it seems that noone has ever got this to work, only the authors over at influxdata/telegraf/tree/master/plugins/inputs/suricata
- I am not allowed to post more than 2 links as I am a new user
PS: Yes, as this is OPNsense based on BSD, I have increased the localhost buffer space stated in README.md;
Under FreeBSD it is necessary to increase the localhost buffer space to at least 16384, default is 8192 otherwise messages from Suricata are truncated as they exceed the default available buffer space, consequently no statistics are processed by the plugin.
sysctl -a | grep local.stream
net.local.stream.recvspace: 16384
net.local.stream.sendspace: 16384
