Is there a known problem with Chronograf 1.3.3.0 where it says There was a problem loading hosts, and won’t connect to Kapacitor?
The Chronograf 1.3.1-alpine container I was using worked just fine with the same configuration.
Although, 1.3.1 throws a Local setting failed: TypeError: Cannot read property 'VERSION' of null, but it at least connects and sees hosts and alerts / alerting endpoints correctly.
Previous versions of Chronograf generated none of these errors.
