Hi!
I’m trying to manage secrets via HTTP API. I receive error 404 page not found, for example:
curl --location 'http://192.168.1.1:8086/api/v2/orgs/f239f1323701088d/secrets' \
--header 'Authorization: Token {TOKEN}'
"code": "not found",
"message": "404 page not found"
The token I am using should work - it is used by telegraf and it is working fine.
Hello @khataev,
Hmm thats very odd.
Could your org id be wrong?
I justs tried it for myself and I get this response
"links": {
"org": "/api/v2/orgs/9c2a84885dbca853",
"self": "/api/v2/orgs/9c2a84885dbca853/secrets"
"secrets": []
@Anaisdg I found the reason - the telegraf token I used had limited permissions (only to write to the bucket and not list of tokens). I created all access token and problem solved. Thanks!
