Since the upgrade from 2.0 to 2.1 i have some trouble accessing database through API V1.
I can’t write with Telegraf 1.20.4, the same config i was using before send me to this :
2021-12-14T13:30:00Z E! [outputs.influxdb] E! [outputs.influxdb] Failed to write metric (will be dropped: 404 Not Found):
Telegraf output config :
[[outputs.influxdb]]
urls = ["http://127.0.0.1:8086"]
database = "elasticsearch"
username = "metrics"
password = "xxxxxxxxx"
skip_database_creation = true
[outputs.influxdb.tagpass]
tag1 = [ "elasticsearch" ]
I can’t access to the database anymore with Gafana 8.3.2, the database test succeed , but it can’t see the retention policies so it failed to load mesurements list.
Event with curl, i doesn’t work anymore :
curl -k http://localhost:8086/query -u 'metrics:xxxxxx.' -d q='SHOW RETENTION POLICIES on "elasticsearch"'
My config in Influx :
$ influx bucket list
ID Name Retention Shard group duration Organization ID Schema Type
1980a638df195248 elasticsearch 720h0m0s 24h0m0s 920ba989433e2dc2 implicit
$ influx v1 dbrp list
ID Database Bucket ID Retention Policy Default Organization ID
089a40d43f544000 elasticsearch 1980a638df195248 default true 920ba989433e2dc2
$ influx v1 auth list
ID Description Username v2 User Name v2 User ID Permissions
089a41d411d44000 metrics admin 089a3d246c944000 [read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 read:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6 write:orgs/920ba989433e2dc2/buckets/f929e76fc37151d6]
Any idea ?
