As of this week, Influx (running Docker:latest) has stopped working for me. Docker log shows it has completed startup:
ts=2025-03-31T19:13:48.289659Z lvl=info msg="Opened shard" log_id=0vcPojl0000 service=storage-engine service=store op_name=tsdb_open index_version=tsi1 path=/var/lib/influxdb2/engine/data/91cc17f74bb2e656/autogen/816 duration=848.837ms
ts=2025-03-31T19:13:48.731664Z lvl=info msg="Opened shard" log_id=0vcPojl0000 service=storage-engine service=store op_name=tsdb_open index_version=tsi1 path=/var/lib/influxdb2/engine/data/91cc17f74bb2e656/autogen/834 duration=904.924ms
ts=2025-03-31T19:13:48.749660Z lvl=info msg="Open store (end)" log_id=0vcPojl0000 service=storage-engine service=store op_name=tsdb_open op_event=end op_elapsed=17811.251ms
ts=2025-03-31T19:13:48.750166Z lvl=info msg="Starting retention policy enforcement service" log_id=0vcPojl0000 service=retention check_interval=30m
ts=2025-03-31T19:13:48.750274Z lvl=info msg="Starting precreation service" log_id=0vcPojl0000 service=shard-precreation check_interval=10m advance_period=30m
ts=2025-03-31T19:13:48.795089Z lvl=info msg="Starting query controller" log_id=0vcPojl0000 service=storage-reads concurrency_quota=1024 initial_memory_bytes_quota_per_query=9223372036854775807 memory_bytes_quota_per_query=9223372036854775807 max_memory_bytes=0 queue_size=1024
ts=2025-03-31T19:13:48.816580Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0vcPojl0000 max_select_point=0 max_select_series=0 max_select_buckets=0
ts=2025-03-31T19:13:49.076514Z lvl=info msg=Listening log_id=0vcPojl0000 service=tcp-listener transport=http addr=:8086 port=8086
However, login screen does not open:
❯ curl http://nas.fritz.box:9999/orgs/5d4718f7355f8f75/dashboards-list
<!doctype html><html lang="en"><head><meta charset="utf-8"><meta name="viewport" content="width=device-width,initial-scale=1"><meta name="description" content="InfluxDB is a time series platform, purpose-built by InfluxData for storing metrics and events, provides real-time visibility into stacks, sensors, and systems."><title>InfluxDB</title><base href="/"><base href=""><link rel="icon" href="/favicon.ico"></head><body><div id="react-root" data-basepath=""></div><script defer="defer" src="/837ff3b893.js"></script></body></html>%
Apparently the script files never get served:
Restarting doesn’t change that in any way.
