Hello everyone,
I have setup a new system with InfluxDB and would love to use the dashboard properly.
I setup a few graphs that display the data I want, but right now not the way I want it.
Here is an example:
SELECT mean("value") AS "mean_value" FROM "homeassistant"."autogen"."W" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND ("entity_id"='ambient_light_dr_power' OR "entity_id"='ambient_light_l_dr_power' OR "entity_id"='ambient_light_lr_power' OR "entity_id"='ambient_light_r_dr_power' OR "entity_id"='boiler_1_power' OR "entity_id"='boiler_2_power' OR "entity_id"='boiler_3_power' OR "entity_id"='fridge_energy_power' OR "entity_id"='main_light_dr_power' OR "entity_id"='main_light_lr_power' OR "entity_id"='naim_audio_av2_energy_power' OR "entity_id"='plasma_energy_power' OR "entity_id"='sony_kd75xf9005_energy_power' OR "entity_id"='travel_energy_power') GROUP BY time(:interval:) FILL(null)
The Problems:
All sensors are displayed as a total. I am guessing this is due to the standard selection as mean(“value”) AS “mean_value” but what would be the correct syntax? Or is it because they are listed as OR rather than AND statements?
I also considered creating multiple queries, but that would be 20 times the work. With one query I can just click the 20 entities in one go. -
How can I adjust the default relative time in the dashboard? And will it always overried the time interval defined in the respective graphs? I set a value per graph but when I open the dashboard, they all use the dashboard value.
I tried searching through Explore data using InfluxQL | InfluxDB OSS 1.8 Documentation but I got lost and couldn’t get my problem solved ![]()
Sorry for my newbieness ![]()
Best regards
Alex
