Hi I am new in with influxDB and I need to bring the value in _time column.
What else do I need to add in order to get that value? I do not need the whole table, just that value.
This is my query.
from (bucket: “jmeter”)
|>(start: v.timeRangeStart, stop: v.timeRangeStop)
|>(fn: (r) => r.[“_measrurement”] == “requestsRaw”)
|>group(columns: [“_start”])
Thank you
Hi @Diego_Navea,
So you could use the get column function like so:
timeArray = from (bucket: “jmeter”)
|> getColumn(column: "_time")
time = timeArray[0]
Hi @Jay_Clifford ,
Thank you for replying. I did not know that you can use arrays but when I run the query I am getting the error " An internal error has occurred"
When I tried to display the graph replacing the v.TimeRangeStart for the value in the array (time) is shows this error, " type error @5:29-5:30: record is missing label windowPeriod"
No idea what that means…
My final goal is to replace the v.timeRangeStart with whatever value is in _time
Also, can I apply conditions statement (such as an if) at the moment to select the _time?
Thank you in advance.
Hi @Diego_Navea,
Oh, in that case, I would just use a map()
Like this:
from(bucket: "global")
|> filter(fn: (r) => r._measurement == "machine_data")
|> filter(fn: (r) => r._field == "load")
|> map(fn: (r) => ({ r with _time: r._start }))
|> yield(name: "_editor_composition")
You also run conditional statements like so:
if r._value > 200 then
"FAULT"
else if r._value == 0 then
r._start
else
r._time
