I’ve been using Influx 1.8 for quite a while and now upgraded to 2.4.
I did so based on an upgrade command trying to control the paths for the database, specifically I used:
sudo influxd upgrade
–config-file=“/etc/influxdb/influxdb.conf”
–influx-configs-path=“/db/influxdb_v2/Logging.conf”
–bolt-path=“/db/influxdb_v2/logging.bolt”
–engine-path=“/db/influxdb_v2/Logging/engine”
–continuous-query-export-path=“/db/influxdb_v2/Logging/scripts/cs.sql”
–v2-config-path=“/db/influxdb_v2/dba/Logging/cfg/Logging.toml”
–log-path=“/db/influxdb_v2/dba/Logging/log/upgrade.log”
–bucket=“Logging”
–org=“xxx”
–username=“dba” \
Everything works fine so far, at least when I start the server with
sudo nohup influxd --engine-path=/db/influxdb_v2/Logging/engine --bolt-path=/db/influxdb_v2/logging.bolt run
I’m now trying to move that over to a process starting automatically at boot-time.
I’m feeling bad, but I was not yet able to do so, some paths of standard installation interfere and the server is starting with a fresh database.
Would be grateful for a hint on how to start the server or where to place the config file exactly.
