I have configured our InfluxDB instance with user authorization using three profiles: one for database administration, one for the main application to be able to write to the database, and the third is for read-only access to the database (for reporting and ad-hoc queries).
Is it possible to configure InfluxDB so that authorization is required for admin or write access, but not required for read-only access?
I don’t believe this is something we currently support. You may want to open an feature request issue on GitHub.
As a workaround, you may be able to set up a proxy that adds the basic auth headers to incoming GETs to the /query endpoint. I haven’t tried that out personally but it ought to be straightforward with nginx or caddy.
