I am trying to collect some metrics of MS SQL Server. They are in perfmon.
I added the following section in telegraf.conf
I restart the serice and use the -test command. I do not see error, but I do not see the counter. Neither in the datas of influxdb.
[[inputs.win_perf_counters.object]]
ObjectName = “MSSQL$xxxxx:Locks”
Instances = [“_Total”]
Counters = [“Lock Requests/s”]
Measurement = “sql_locks”
Is it normal ?
You are missing a part (or maybe you forgot it) and there might be a TOML escaping-related issue
when using double quotes / must be escaped in strings, meaning it has to be written as //. to avoid it you can use single quotes
[[inputs.win_perf_counters]] <-- this was missing
Counters = ['Lock Requests/s'] <-- single quotes here
Since you are getting it from perfmon it should work.
You are right on both points. It’s OK now (I’m completely new on Telegraf).
Thank you for the help
