I am trying to display the total energy usage from devices in grafana backed by influxdb however the value for the sum is wrong. Here are the two queries for example.
SELECT sum("value") FROM (SELECT last("value") - first("value") AS "value" FROM "kWh" WHERE $timeFilter GROUP BY "entity_id") WHERE $timeFilter
As you can see it’s showing 0.99 as the sum when It should be 1.7.
Update and now again with influxdb CLI
> SELECT last("value") - first("value") AS "value" FROM "kWh" WHERE time > now() - 24h GROUP BY "entity_id"
tags: entity_id=socketcoffee_energy
time value
1537863368390823721 0.41900000000000004
tags: entity_id=socketdesk_energy
time value
1537863368390823721 0.17999999999999994
tags: entity_id=socketmedia_energy
time value
1537863368390823721 0.4980000000000002
tags: entity_id=sockettable_energy
time value
1537863368390823721 0.049999999999999996
And SUM
> SELECT sum("value") FROM (SELECT last("value") - first("value") AS "value" FROM "kWh" WHERE time > now() - 24h GROUP BY "entity_id")
time sum
0 0.5480000000000003
