Hi people!
First off, while I have some knowledge of working with time series database and grafana (although grafana is not involved here), I have only been messing around with InfluxDB on a personal basis. And everything is a bit new.
I have a bunch of very scarce data (maybe a couple points per month for a given tag in the measurement I’m working on).
And I’m trying to compute the sum of all these points, but the results are not what I would expect.
So let’s assume we have the following set of data:
insert values,t=0 value=1 1514786400000000000
insert values,t=0 value=2 1514959200000000000
insert values,t=1 value=1 1514959200000000000
insert values,t=0 value=3 1515045600000000000
select * from "values"
time tag value
2018-01-01T06:00:00Z 0 1
2018-01-03T06:00:00Z 0 2
2018-01-03T06:00:00Z 1 1
2018-01-04T06:00:00Z 0 3
Which is what we would expect.
Now the end result I’m basically trying to achieve is this:
2018-01-01T06:00:00Z 1
2018-01-02T06:00:00Z 1
2018-01-03T06:00:00Z 3
2018-01-04T06:00:00Z 4
Where, on a daily basis, you get the sum of everything, whatever the tags are.
My (obviously dumb) first try looked like this:
select sum(*) from "values" where time >= 1514786400000000000 and time <= 1515045600000000000 group by time(1d) fill(previous)
time sum_value
2018-01-01T00:00:00Z 1
2018-01-02T00:00:00Z 1
2018-01-03T00:00:00Z 3
2018-01-04T00:00:00Z 3
This doesn’t work for obvious reasons.
Now, this gives me something closer to what I want:
select sum(*) from "values" where time >= 1514786400000000000 and time <= 1515045600000000000 group by t,time(1d) fill(previous)
tags: t=0
time sum_value
2018-01-03T00:00:00Z 2
tags: t=1
time sum_value
2018-01-03T00:00:00Z 1
2018-01-04T00:00:00Z 1
This is valid. I keep previous values. I have one datapoint a day for each tag. And… I don’t seem to be able to add these properly…
select sum(*) from(select sum(*) from "values" where time >= 1514786400000000000 and time <= 1515045600000000000 group by t,time(1d) fill(previous)) where time >= 1514786400000000000 and time <= 1515045600000000000 group by time(1d)
time sum_sum_value
2018-01-04T00:00:00Z 2
2018-01-04T00:00:00Z 4
While technically true, this is not really what I was expecting. I would expect group by time() to… group by time.
I tried to order by time but it didn’t seem to do anything.
Also:
select sum(*) from (select sum(*) from "values" where time >= 1514786400000000000 and time <= 1515045600000000000 group by t,time(1d) fill(previous))
time sum_sum_value
1970-01-01T00:00:00Z 11
I feel like this should be 9. Not 11.
But that probably boils down to the same explanation as to why my previous requests don’t really do what I expect them to.
So yeah. I guess my question is can anyone provide me with a request that actually does what I want? And explain what I’m missing while we are at it
If the answer is: you need to organize your data differently -> that’s fine too.
Thanks for the help!
Alexis
[EDIT] Forgot to mention I’m running InfluxDB version 1.4.2
