I’m having issues getting my vmware data to write to the vmware bucket and not the linux bucket.
I’m using ansible to template out the correct information and it is doing it correctly, but my hosts that is pulling my vmware data is also writing it to the linux bucket and I don’t want this.
Here is the output config for all my linux boxes
[[inputs.cpu]]
percpu = true
totalcpu = true
# collect_cpu_time = true
# report_active = true
fielddrop = ["time_*"]
[[inputs.mem]]
[[inputs.system]]
[[inputs.net]]
fieldpass = [ "bytes*" ]
[[inputs.swap]]
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "iso9660", "overlay", "aufs", "squashfs"]
[[inputs.processes]]
[[inputs.diskio]]
namepass = ["cpu_*","mem_*","system_*","net_*","swap_*","disk_*","processes_*","diskio_*"]
# OUTPUT PLUGINS #
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
urls = ["http://{{ influxdb_url }}"]
organization = "{{ influxdb_primary_org }}"
token =
bucket =
And here is the output for the vmware section running on just one system.
## Realtime instance
[[inputs.vsphere]]
interval = "20s"
vcenters = [ "{{ vcenter_hostname }}/sdk" ]
username = "{{ vcenter_influxdb_username }}"
password = "{{ vcenter_influxdb_password }}"
insecure_skip_verify = true
#Include
vm_include = ["/{{ vm_guest_cluster }}/vm/{{ vm_guest_folder }}/*"]
vm_metric_include = ["*"]
host_metric_include = ["*"]
# Exclude all historical metrics
datastore_metric_exclude = ["*"]
collect_concurrency = 4
discover_concurrency = 4
max_query_metrics = 256
timeout = "60s"
object_discovery_interval = "60s"
namepass = ["vsphere_*","vm_metric_include_*","host_metric_include_*"]
token1 = "tokenvalue"
bucket1 = "vmware"
# HISTORICAL DATA #
## Historical instance
[[inputs.vsphere]]
interval = "300s"
datastore_metric_include = [ "disk.capacity.latest", "disk.used.latest", "disk.provisioned.latest" ]
cluster_metric_include = []
datacenter_metric_include = []
host_metric_exclude = ["*"] # Exclude realtime metrics
vm_metric_exclude = ["/{{ vm_guest_cluster }}/vm/{{ vm_guest_folder }}/*"] # Exclude realtime metrics
collect_concurrency = 3
namepass = ["datastore_metric_include_*","cluster_metric_include_*","datacenter_metric_include_*"]
token2 = "key2"
bucket2 = "vmware"
I use the values for token and token# gets replace with the correct values.
I’m getting vmware data, but no linux data on any of my machines
