Write data in different buckets using telegraf
Hi all,
I am using Telegraf and InfluxDB together.
I was wondering is it possible to write different plugin metrics each in their own bucket?
To do this I tried using the --config-directory property. I searched the documentation but found only this https://docs.influxdata.com/telegraf/v1.21/administration/configuration/#configuration-file-locations
This is my implementation:
telegraf/
├─ telegraf.d/
│ ├─ ModbusRTU.conf
│ ├─ InternlMonitor.conf
├─ telegraf.conf
# Telegraf.conf
[global_tags]
[agent]
  interval = "10s"
  round_interval = true
  metric_batch_size = 1000
  metric_buffer_limit = 10000
  collection_jitter = "0s"
  flush_interval = "10s"
  flush_jitter = "0s"
  precision = "0s"
  hostname = ""
  omit_hostname = false
# InternalMonitor.conf
#                            OUTPUT PLUGINS                                   #
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
alias = "telegraf-stats-db"
  urls = ["http://127.0.0.1:8086"]
  token = "token"
  organization = "xxx"
  bucket = "InternalMonitor"
##                            INPUT PLUGINS                                    #
# Collect statistics about itself
[[inputs.internal]]
alias = "telegraf-monitor"
name = "telegraf-monitor"
  ## If true, collect telegraf memory stats.
  collect_memstats = true
# ModbusRTU.conf
#                            OUTPUT PLUGINS                                   #
  token = "token"
  bucket = "ModbusRTU"
##                            INPUT PLUGINS                                    #
[[inputs.modbus]]
  alias = "modbus RTU"
  name = "modbus RTU"
  timeout = "1s"
  busy_retries = 1
  busy_retries_wait = "100ms"
  ## Serial (RS485; RS232)
  controller = "file:///COM1"
  baud_rate = 9600
  data_bits = 8
  parity = "N"
  stop_bits = 2
  transmission_mode = "RTU"
  debug_connection = false
  configuration_type = "request"
  [[inputs.modbus.request]]
    slave_id = 1
    byte_order = "ABCD"
    register = "input"
    fields = [
    { address =200 , name = "Phase to neutral Voltage, THD 1" ,type =  "FLOAT32", measurement = "%",omit = false },
    { address =202 , name = "Phase to phase Voltage, THD 2" ,type =  "FLOAT32", measurement = "%",omit = false },
    { address =204 , name = "Phase to phase Voltage, THD 3" ,type =  "FLOAT32", measurement = "%",omit = false },
    [inputs.modbus.request.tags]
      location = "zoo"
      deviceName = "fido 1"
The problem is that with this configuration each plugin is write in both buckets.
Is there a way to have each plugin written in different buckets?
I’m sure I don’t quite understand the --config-directory parameter can someone enlighten me or give me the link to a useful document?
OS win 10
Telegraf v1.24(nightly version)
InfluxDB v2.2.0
This parameter only allows you to specify a folder to look for configurations. Internally all the files are read and combined into one big config.
What you are looking for is the namepass/tagpass metric selctor config options which help you route metrics to specific plugins.
You could add namepass = ["<metric name>"] to the output you want to collect those metrics, and only those would go there.
Wow! everything is clear now
So to get a sorting I could do it this way
  token = "token"
[outputs.influxdb.tagpass]
    alias = ["modbus RTU"]
In this way, only the measurement with an alias equal to “modbus RTU” will pass
Thanks, @jpowers :smiley:
