olsonnn
December 27, 2020, 3:04pm
1
What I want:
system related data > default bucket
telegraf input1 > bucket 1
telegraf input2 > bucket 2
telegraf input3 > bucket 3 etc…
to keep everything clean with separate retention times.
My problem with this is that i need to know upfront to what fields are inserted in to the bucket to make use of namedrop and namepass
My result: bucket with data that is not related with each other. > mess
Is there a better way to do this: keep data separated based on telegraf input plugin?
I got it to work with by tagging the input and adding tagpass in the output
<!-- markdownlint-disable MD024 -->
# Configuration
Telegraf's configuration file is written using [TOML][] and is composed of
three sections: [global tags][], [agent][] settings, and [plugins][].
View the default [telegraf.conf][] config file with all available plugins.
## Generating a Configuration File
A default config file can be generated by telegraf:
```sh
telegraf config > telegraf.conf
To generate a file with specific inputs and outputs, you can use the
--input-filter and --output-filter flags:
This file has been truncated. show original
[[outputs.influxdb_v2]]
urls = [“ipport”]
token = “tkn”
organization = “org”
bucket = “bkt”
tagexclude =[“tag1”]
[outputs.influxdb_v2.tagpass]
tag1 = [“foo”]
[[inputs.socket_listener]]
service_address = “tcp://:2003”
data_format = “graphite”
templates = [
“.app env.service.resource.measurement",
"servers. .host.resource.measurement.field*”,
[inputs.socket_listener.tags]
tag1 = “foo”
You can also use the name_override and namepass to filter measurements.
name_override - changes a measurement name for the inputs, useful for self-owned scripts.
namepass - filters the measurements to send to influx, defined in the outputs.
An example can be:
urls = ["http://localhost:8086"]
token = "sadojpqrq9we894e6461e4614d6a46gwajg4g=="
organization = "awesome_org"
bucket = "system_data"
namepass = ["mem", "processes"]
[[inputs.processes]]
[[inputs.mem]]
or
namepass = ["kernel"]
[[inputs.exec]]
name_override = "kernel"
commands = [
"/etc/telegraf/kernel.bash"
interval = "1m"
timeout = "5s"
data_format = "logfmt"
Where /etc/telegraf/kernel.bash is a script that outputs data in logfmt format.
