Hello Davidgs,
Thanks for the reply,
Here is my telegraf.conf
[[inputs.snmp]]
agents = [ “switchIP”, “switchIP”, ]
## SNMPv3 auth parameters
interval = “10s”
sec_name = “public”
auth_protocol = “SHA” # Values: “MD5”, “SHA”, “”
auth_password = “mypassword”
sec_level = “authPriv” # Values: “noAuthNoPriv”, “authNoPriv”, “authPriv”
context_name = “”
priv_protocol = “AES” # Values: “DES”, “AES”, “”
priv_password = “mypassword”
version = 3
community = “public”
name = “snmp”
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
is_tag = true
[[inputs.snmp.table]]
name = “snmp”
inherit_tags = [ “hostname” ]
oid = “IF-MIB::ifXTable”
name = “load”
oid = “.1.0.0.1.3”
[[inputs.snmp.table.field]]
name = “ifName”
oid = “IF-MIB::ifName”
is_tag = true
name = “uptime”
oid = “SNMP-FRAMEWORK-MIB::snmpEngineTime.0”
IF-MIB::ifTable contains counters on input and output traffic as well as errors and discards.
#[[inputs.snmp.table]]
name = “interface”
oid = "IF-MIB::ifTable
#added more fields
name = “sysUpTime”
oid = “.1.3.6.1.2.1.1.3.0”
name = “dot1dBaseBridgeAddress”
oid = “.1.3.6.1.2.1.17.1.1.0”
is_tag = true
conversion = “hwaddr”
name = “entPhysicalName”
oid = “.1.3.6.1.2.1.47.1.1.1.1.7.1”
is_tag = true
name = “entPhysicalSerialNum”
oid = “.1.3.6.1.2.1.47.1.1.1.1.11.1”
is_tag = true
name = “ifIndex”
oid = “.1.3.6.1.2.1.2.2.1.1”
oid = “IF-MIB::ifIndex”
#last using
oid = “IF-MIB::=ifXEntry 1”
is_tag = true
name = “ifDescr”
oid = “.1.3.6.1.2.1.2.2.1.2”
is_tag = true
name = “ifPhysAddress”
oid = “.1.3.6.1.2.1.2.2.1.6”
is_tag = true
name = “ifSpeed”
oid = “.1.3.6.1.2.1.2.2.1.5”
name = “ifOperStatus”
oid = “.1.3.6.1.2.1.2.2.1.8”
name = “ifLastChange”
oid = “.1.3.6.1.2.1.2.2.1.9”
name = “ifInOctets”
oid = “.1.3.6.1.2.1.2.2.1.10”
name = “ifInErrors”
oid = “.1.3.6.1.2.1.2.2.1.14”
name = “ifOutOctets”
oid = “.1.3.6.1.2.1.2.2.1.16”
name = “ifOutErrors”
oid = “.1.3.6.1.2.1.2.2.1.20”
[[outputs.influxdb]]
urls = [“http://influxdb:8086”]
When I am passing snmpwalk command at VM level I could see data, I googled it, I need to properly set my telegraf.conf, but it was able collect data previously but not now.
Tried with influxdb and with IP Address, no result
urls = [“[http://IPAddress:8086/)”]
Here is my telegraf.log
root@ubuntu:/etc/telegraf# cat telegraf.log
2019-05-15T11:07:57Z I! Loaded inputs: snmp
2019-05-15T11:07:57Z I! Loaded aggregators:
2019-05-15T11:07:57Z I! Loaded processors:
2019-05-15T11:07:57Z I! Loaded outputs: influxdb
2019-05-15T11:07:57Z I! Tags enabled: host=ubuntu
2019-05-15T11:07:57Z I! [agent] Config: Interval:1m0s, Quiet:false, Hostname:“ubuntu”, Flush Interval:20s
2019-05-15T11:07:57Z D! [agent] Connecting outputs
2019-05-15T11:07:57Z D! [agent] Attempting connection to output: influxdb
2019-05-15T11:07:57Z W! [outputs.influxdb] when writing to [http://localhost:8086]: database “” creation failed: Post http://localhost:8086/query: dial tcp [::1]:8086: connect: connection refused
2019-05-15T11:07:57Z D! [agent] Successfully connected to output: influxdb
2019-05-15T11:07:57Z D! [agent] Starting service inputs
2019-05-15T11:08:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:08:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:09:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:09:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:09:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:10:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T11:10:00Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T11:10:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:10:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:11:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:11:18Z D! [agent] Stopping service inputs
2019-05-15T11:11:18Z D! [agent] Input channel closed
2019-05-15T11:11:18Z I! [agent] Hang on, flushing any cached metrics before shutdown
2019-05-15T11:11:18Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-15T11:11:18Z D! [agent] Closing outputs
2019-05-15T11:11:18Z D! [agent] Stopped Successfully
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T11:11:24Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T11:13:17Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T11:13:39Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T12:04:03Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T12:19:26Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-15T12:32:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-16T04:46:04Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-16T04:46:05Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-16T04:46:05Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-16T04:46:05Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-16T04:50:01Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-16T05:29:57Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-16T05:29:57Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-16T05:29:57Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-16T05:29:57Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-16T05:45:33Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifXTable”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “IF-MIB::ifXTable.1”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptable” “-Ch” “-Cl” “-c” “public” “127.0.0.1” “IF-MIB::ifXTable”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifName”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInMulticastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifInBroadcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutMulticastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifOutBroadcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInOctets”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInUcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInMulticastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCInBroadcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutOctets”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutUcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutMulticastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHCOutBroadcastPkts”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifLinkUpDownTrapEnable”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifHighSpeed”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifPromiscuousMode”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifConnectorPresent”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifAlias”
2019-05-16T11:58:08Z D! [inputs.snmp] Executing “snmptranslate” “-Td” “-Ob” “IF-MIB::ifCounterDiscontinuityTime”
2019-05-16T12:19:36Z I! Loaded inputs: snmp
2019-05-16T12:19:36Z I! Loaded aggregators:
2019-05-16T12:19:36Z I! Loaded processors:
2019-05-16T12:19:36Z I! Loaded outputs: influxdb
2019-05-16T12:19:36Z I! Tags enabled: host=ubuntu
2019-05-16T12:19:36Z I! [agent] Config: Interval:1m0s, Quiet:false, Hostname:“ubuntu”, Flush Interval:20s
2019-05-16T12:19:36Z D! [agent] Connecting outputs
2019-05-16T12:19:36Z D! [agent] Attempting connection to output: influxdb
2019-05-16T12:19:36Z W! [outputs.influxdb] when writing to [http://localhost:8086]: database “” creation failed: Post http://localhost:8086/query: dial tcp [::1]:8086: connect: connection refused
2019-05-16T12:19:36Z D! [agent] Successfully connected to output: influxdb
2019-05-16T12:19:36Z D! [agent] Starting service inputs
2019-05-16T12:19:47Z D! [agent] Stopping service inputs
2019-05-16T12:19:47Z D! [agent] Input channel closed
2019-05-16T12:19:47Z I! [agent] Hang on, flushing any cached metrics before shutdown
2019-05-16T12:19:47Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-05-16T12:19:47Z D! [agent] Closing outputs
2019-05-16T12:19:47Z D! [agent] Stopped Successfully
Dashboard, which is showing data of last 30 days, not the present.
Any help would be appreciated.
Thank you.
