Hi, I tried a lot of setup on synology nas - docker and also with portainer
I started with version 2.0 but aftern an updrade to latest version my Influxdb stopped to work.
The error is always the same:
WARN: Write to InfluxDB failed (attempt: 1). b [RequestTimedOutError]: Request timed out
at ClientRequest.<anonymous> (/opt/reactor/node_modules/@influxdata/influxdb-client/dist/index.js:16:4115)
at ClientRequest.emit (node:events:520:28)
at ClientRequest.emit (node:domain:475:12)
at Socket.emitRequestTimeout (node:_http_client:758:9)
at Object.onceWrapper (node:events:639:28)
at Socket.emit (node:events:532:35)
at Socket.emit (node:domain:475:12)
at Socket._onTimeout (node:net:501:8)
at listOnTimeout (node:internal/timers:559:17)
at processTimers (node:internal/timers:502:7)
ERROR: Write to InfluxDB failed (attempt: 3). Error: Max retry time exceeded.
at nt.sendBatch (/opt/reactor/node_modules/@influxdata/influxdb-client/dist/index.js:1:13356)
at Timeout._onTimeout (/opt/reactor/node_modules/@influxdata/influxdb-client/dist/index.js:1:10855)
my configuration is
"config": {
"assets-path": "",
"bolt-path": "/var/lib/influxdb2/influxd.bolt",
"e2e-testing": false,
"engine-path": "/var/lib/influxdb2/engine",
"feature-flags": null,
"flux-log-enabled": false,
"hardening-enabled": false,
"http-bind-address": ":8086",
"http-idle-timeout": 180000000000,
"http-read-header-timeout": 10000000000,
"http-read-timeout": 0,
"http-write-timeout": 0,
"influxql-max-select-buckets": 0,
"influxql-max-select-point": 0,
"influxql-max-select-series": 0,
"log-level": "info",
"metrics-disabled": false,
"nats-max-payload-bytes": 0,
"nats-port": 4222,
"no-tasks": false,
"pprof-disabled": false,
"query-concurrency": 1024,
"query-initial-memory-bytes": 0,
"query-max-memory-bytes": 0,
"query-memory-bytes": 0,
"query-queue-size": 1024,
"reporting-disabled": false,
"secret-store": "bolt",
"session-length": 60,
"session-renew-disabled": false,
"sqlite-path": "/var/lib/influxdb2/influxd.sqlite",
"storage-cache-max-memory-size": 1073741824,
"storage-cache-snapshot-memory-size": 26214400,
"storage-cache-snapshot-write-cold-duration": "10m0s",
"storage-compact-full-write-cold-duration": "4h0m0s",
"storage-compact-throughput-burst": 50331648,
"storage-max-concurrent-compactions": 0,
"storage-max-index-log-file-size": 1048576,
"storage-no-validate-field-size": false,
"storage-retention-check-interval": "30m0s",
"storage-series-file-max-concurrent-snapshot-compactions": 0,
"storage-series-id-set-cache-size": 0,
"storage-shard-precreator-advance-period": "30m0s",
"storage-shard-precreator-check-interval": "10m0s",
"storage-tsm-use-madv-willneed": false,
"storage-validate-keys": false,
"storage-wal-fsync-delay": "0s",
"storage-wal-max-concurrent-writes": 0,
"storage-wal-max-write-delay": 600000000000,
"storage-write-timeout": 10000000000,
"store": "disk",
"testing-always-allow-setup": false,
"tls-cert": "",
"tls-key": "",
"tls-min-version": "1.2",
"tls-strict-ciphers": false,
"tracing-type": "",
"ui-disabled": false,
"vault-addr": "",
"vault-cacert": "",
"vault-capath": "",
"vault-client-cert": "",
"vault-client-key": "",
"vault-client-timeout": 0,
"vault-max-retries": 0,
"vault-skip-verify": false,
"vault-tls-server-name": "",
"vault-token": ""
someone can help in this?
