2018-06-04T04:04:36Z E! [outputs.influxdb]: when writing to [http://172.16.11.47:8086 ]: Post http://172.16.11.47:8086/write?db=telegraf: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
Please solution
Please add more detail to this post so that someone can help you.
What are the steps to reproduce this error? What troubleshooting steps have you already tried?
The most obvious cause of a timeout would be network connectivity issues, so that would be a good place to start investigating.
this error in telegraf log, why?
2018-06-04T03:58:10Z E! [outputs.influxdb]: when writing to [http://172.16.11.47:8086 ]: Post http://172.16.11.47:8086/write?db=telegraf: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2018-06-04T03:58:10Z E! Error writing to output [influxdb]: could not write any address
2018-06-04T03:58:15Z E! [outputs.influxdb]: when writing to [http://172.16.11.47:8086 ]: Post http://172.16.11.47:8086/write?db=telegraf: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2018-06-04T03:58:15Z D! Output [influxdb] buffer fullness: 5059 / 5000 metrics.
2018-06-04T03:58:20Z E! [outputs.influxdb]: when writing to [http://172.16.11.47:8086 ]: Post http://172.16.11.47:8086/write?db=telegraf: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2018-06-04T03:58:20Z E! Error writing to output [influxdb]: could not write any address
2018-06-04T03:58:25Z E! [outputs.influxdb]: when writing to [http://172.16.11.47:8086 ]: Post http://172.16.11.47:8086/write?db=telegraf: read tcp 172.16.11.48:58328->172.16.11.47:8086: wsa
philb
June 5, 2018, 9:53am
4
I’m not sure but you might need to look at metric buffer size.
<!-- markdownlint-disable MD024 -->
# Configuration
Telegraf's configuration file is written using [TOML][] and is composed of
three sections: [global tags][], [agent][] settings, and [plugins][].
View the default [telegraf.conf][] config file with all available plugins.
## Generating a Configuration File
A default config file can be generated by telegraf:
```sh
telegraf config > telegraf.conf
To generate a file with specific inputs and outputs, you can use the
--input-filter and --output-filter flags:
This file has been truncated. show original
I think you’ll need to adjust your configuration to fix this.
Your Telegraf instance is not able to communicate with your InfluxDB instance. There could be many reasons for this, you will need to investigate. Some good places to start are testing your network and looking at the load on your InfluxDB server.
The metrics buffer is likely filling up because Telegraf cannot write points to InfluxDB. Changing the size of the buffer probably won’t help.
Again, you need to provide more detail in order for someone to help you with this issue. What does your installation look like? How many machines, what operating system, are they in the cloud? What metrics are you collecting? How frequently? What troubleshooting steps have you already tried?
I have this same problem. The telegraf and influx are installed on the same machine, that is, it is not a firewall. SELinux is disabled. And yet, it does not communicate.
2018-12-27T13:40:15Z E! [outputs.influxdb] when writing to [https://10.13.0.245:8086 ]: Post https://10.13.0.245:8086/write?db=telegraf: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2018-12-27T13:40:15Z D! [outputs.influxdb] buffer fullness: 18112 / 60000 metrics.
2018-12-27T13:40:15Z E! [agent] Error writing to output [influxdb]: could not write any address
Influx conf:
[http]
#enabled = true
bind-address = “0.0.0.0:8086”
auth-enabled = true
realm = “InfluxDB”
Telegraf conf:
urls = [“https://10.13.0.245:8086 ”]
database = “telegraf”
skip_database_creation = true
timeout = “15s”
HTTP Basic Auth
username = “username”
password = “password”
load average: 0.20, 0.21, 0.24
As I mentioned before, there could be many reasons for this, you will need to investigate. In your case I would start by testing the network. Are you able to make a connection using that IP address and port and a tool like netcat? You can start an instance of netcat that listens on 0.0.0.0:8086 and another instance that connects to 10.13.0.245:8086 to verify that you are able to make a TCP connection.
Is there a reason you’re not using 127.0.0.1 or localhost to connect, since the applications are on the same machine?
My solution was to Restart the db and then run telegraf as Administrator.
i use :
64 Giga Ram
16 Core CPU
HDD 200 Giga
Raw 500.000 / second
and i use 48 telegraf for insert to 1 influxdb
Welcome to the InfluxDB configuration file.
The values in this file override the default values used by the system if
a config option is not specified. The commented out lines are the configuration
field and the default value used. Uncommenting a line and changing the value
will change the value used at runtime when the process is restarted.
Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
The data includes a random ID, os, arch, version, the number of series and other
usage data. No data from user databases is ever transmitted.
Change this option to true to disable reporting.
reporting-disabled = false
Bind address to use for the RPC service for backup and restore.
bind-address = “127.0.0.1:8088”
[meta]
Controls the parameters for the Raft consensus group that stores metadata
about the InfluxDB cluster.
[meta]
Where the metadata/raft database is stored
dir = “/data/influxdb/meta”
Automatically create a default retention policy when creating a database.
retention-autocreate = true
If log messages are printed for the meta service
logging-enabled = true
[data]
Controls where the actual shard data for InfluxDB lives and how it is
flushed from the WAL. “dir” may need to be changed to a suitable place
for your system, but the WAL settings are an advanced configuration. The
defaults should work for most systems.
[data]
The directory where the TSM storage engine stores TSM files.
dir = “/data/influxdb/data”
The directory where the TSM storage engine stores WAL files.
wal-dir = “/data/influxdb/wal”
The amount of time that a write will wait before fsyncing. A duration
greater than 0 can be used to batch up multiple fsync calls. This is useful for slower
disks or when WAL write contention is seen. A value of 0s fsyncs every write to the WAL.
Values in the range of 0-100ms are recommended for non-SSD disks.
wal-fsync-delay = “0s”
wal-fsync-delay = “10s”
The type of shard index to use for new shards. The default is an in-memory index that is
recreated at startup. A value of “tsi1” will use a disk based index that supports higher
cardinality datasets.
index-version = “inmem”
index-version = “tsi1”
Trace logging provides more verbose output around the tsm engine. Turning
this on can provide more useful output for debugging tsm engine issues.
trace-logging-enabled = false
Whether queries should be logged before execution. Very useful for troubleshooting, but will
log any sensitive data contained within a query.
query-log-enabled = true
Settings for the TSM engine
CacheMaxMemorySize is the maximum size a shard’s cache can
reach before it starts rejecting writes.
Valid size suffixes are k, m, or g (case insensitive, 1024 = 1k).
Values without a size suffix are in bytes.
cache-max-memory-size = “1g”
cache-max-memory-size = “60g”
CacheSnapshotMemorySize is the size at which the engine will
snapshot the cache and write it to a TSM file, freeing up memory
cache-snapshot-memory-size = “25m”
cache-snapshot-memory-size = “2g”
CacheSnapshotWriteColdDuration is the length of time at
which the engine will snapshot the cache and write it to
a new TSM file if the shard hasn’t received writes or deletes
cache-snapshot-write-cold-duration = “10m”
CompactFullWriteColdDuration is the duration at which the engine
will compact all TSM files in a shard if it hasn’t received a
write or delete
compact-full-write-cold-duration = “4h”
The maximum number of concurrent full and level compactions that can run at one time. A
value of 0 results in 50% of runtime.GOMAXPROCS(0) used at runtime. Any number greater
than 0 limits compactions to that value. This setting does not apply
to cache snapshotting.
max-concurrent-compactions = 0
The threshold, in bytes, when an index write-ahead log file will compact
into an index file. Lower sizes will cause log files to be compacted more
quickly and result in lower heap usage at the expense of write throughput.
Higher sizes will be compacted less frequently, store more series in-memory,
and provide higher write throughput.
max-index-log-file-size = “1m”
The maximum series allowed per database before writes are dropped. This limit can prevent
high cardinality issues at the database level. This limit can be disabled by setting it to
0.
max-series-per-database = 1000000
max-series-per-database = 0
The maximum number of tag values per tag that are allowed before writes are dropped. This limit
can prevent high cardinality tag values from being written to a measurement. This limit can be
disabled by setting it to 0.
max-values-per-tag = 100000
max-values-per-tag = 0
If true, then the mmap advise value MADV_WILLNEED will be provided to the kernel with respect to
TSM files. This setting has been found to be problematic on some kernels, and defaults to off.
It might help users who have slow disks in some cases.
tsm-use-madv-willneed = false
[coordinator]
Controls the clustering service configuration.
[coordinator]
The default time a write request will wait until a “timeout” error is returned to the caller.
write-timeout = “10s”
The maximum number of concurrent queries allowed to be executing at one time. If a query is
executed and exceeds this limit, an error is returned to the caller. This limit can be disabled
by setting it to 0.
max-concurrent-queries = 0
The maximum time a query will is allowed to execute before being killed by the system. This limit
can help prevent run away queries. Setting the value to 0 disables the limit.
query-timeout = “0s”
The time threshold when a query will be logged as a slow query. This limit can be set to help
discover slow or resource intensive queries. Setting the value to 0 disables the slow query logging.
log-queries-after = “0s”
The maximum number of points a SELECT can process. A value of 0 will make
the maximum point count unlimited. This will only be checked every second so queries will not
be aborted immediately when hitting the limit.
max-select-point = 0
The maximum number of series a SELECT can run. A value of 0 will make the maximum series
count unlimited.
max-select-series = 0
The maxium number of group by time bucket a SELECT can create. A value of zero will max the maximum
number of buckets unlimited.
max-select-buckets = 0
[retention]
Controls the enforcement of retention policies for evicting old data.
[retention]
Determines whether retention policy enforcement enabled.
enabled = true
The interval of time when retention policy enforcement checks run.
check-interval = “30m”
[shard-precreation]
Controls the precreation of shards, so they are available before data arrives.
Only shards that, after creation, will have both a start- and end-time in the
future, will ever be created. Shards are never precreated that would be wholly
or partially in the past.
[shard-precreation]
Determines whether shard pre-creation service is enabled.
enabled = true
The interval of time when the check to pre-create new shards runs.
check-interval = “10m”
The default period ahead of the endtime of a shard group that its successor
group is created.
advance-period = “30m”
Controls the system self-monitoring, statistics and diagnostics.
The internal database for monitoring data is created automatically if
if it does not already exist. The target retention within this database
is called ‘monitor’ and is also created with a retention period of 7 days
and a replication factor of 1, if it does not exist. In all cases the
this retention policy is configured as the default for the database.
[monitor]
Whether to record statistics internally.
store-enabled = true
The destination database for recorded statistics
store-database = “_internal”
The interval at which to record statistics
store-interval = “10s”
[http]
Controls how the HTTP endpoints are configured. These are the primary
mechanism for getting data into and out of InfluxDB.
[http]
Determines whether HTTP endpoint is enabled.
enabled = true
The bind address used by the HTTP service.
bind-address = “:8086”
bind-address = “127.0.0.1:8086”
Determines whether user authentication is enabled over HTTP/HTTPS.
auth-enabled = false
The default realm sent back when issuing a basic auth challenge.
realm = “InfluxDB”
Determines whether HTTP request logging is enabled.
log-enabled = true
Determines whether the HTTP write request logs should be suppressed when the log is enabled.
suppress-write-log = false
When HTTP request logging is enabled, this option specifies the path where
log entries should be written. If unspecified, the default is to write to stderr, which
intermingles HTTP logs with internal InfluxDB logging.
If influxd is unable to access the specified path, it will log an error and fall back to writing
the request log to stderr.
access-log-path = “”
Determines whether detailed write logging is enabled.
write-tracing = false
Determines whether the pprof endpoint is enabled. This endpoint is used for
troubleshooting and monitoring.
pprof-enabled = true
Enables a pprof endpoint that binds to localhost:6060 immediately on startup.
This is only needed to debug startup issues.
debug-pprof-enabled = false
Determines whether HTTPS is enabled.
https-enabled = false
The SSL certificate to use when HTTPS is enabled.
https-certificate = “/etc/ssl/influxdb.pem”
Use a separate private key location.
https-private-key = “”
The JWT auth shared secret to validate requests using JSON web tokens.
shared-secret = “”
The default chunk size for result sets that should be chunked.
max-row-limit = 0
The maximum number of HTTP connections that may be open at once. New connections that
would exceed this limit are dropped. Setting this value to 0 disables the limit.
max-connection-limit = 0
Enable http service over unix domain socket
unix-socket-enabled = false
The path of the unix domain socket.
bind-socket = “/var/run/influxdb.sock”
The maximum size of a client request body, in bytes. Setting this value to 0 disables the limit.
max-body-size = 25000000
max-body-size = 0
The maximum number of writes processed concurrently.
Setting this to 0 disables the limit.
max-concurrent-write-limit = 0
The maximum number of writes queued for processing.
max-enqueued-write-limit = 0
The maximum duration for a write to wait in the queue to be processed.
Setting this to 0 or setting max-concurrent-write-limit to 0 disables the limit.
enqueued-write-timeout = 0
[ifql]
Configures the ifql RPC API.
[ifql]
Determines whether the RPC service is enabled.
enabled = true
Determines whether additional logging is enabled.
log-enabled = true
The bind address used by the ifql RPC service.
bind-address = “:8082”
[logging]
Controls how the logger emits logs to the output.
[logging]
Determines which log encoder to use for logs. Available options
are auto, logfmt, and json. auto will use a more a more user-friendly
output format if the output terminal is a TTY, but the format is not as
easily machine-readable. When the output is a non-TTY, auto will use
logfmt.
format = “auto”
Determines which level of logs will be emitted. The available levels
are error, warn, info, and debug. Logs that are equal to or above the
specified level will be emitted.
level = “info”
Suppresses the logo output that is printed when the program is started.
The logo is always suppressed if STDOUT is not a TTY.
suppress-logo = false
[subscriber]
Controls the subscriptions, which can be used to fork a copy of all data
received by the InfluxDB host.
[subscriber]
Determines whether the subscriber service is enabled.
enabled = true
The default timeout for HTTP writes to subscribers.
http-timeout = “30s”
Allows insecure HTTPS connections to subscribers. This is useful when testing with self-
signed certificates.
insecure-skip-verify = false
The path to the PEM encoded CA certs file. If the empty string, the default system certs will be used
ca-certs = “”
The number of writer goroutines processing the write channel.
write-concurrency = 40
The number of in-flight writes buffered in the write channel.
write-buffer-size = 1000
[[graphite]]
Controls one or many listeners for Graphite data.
[[graphite]]
Determines whether the graphite endpoint is enabled.
enabled = false
database = “graphite”
retention-policy = “”
bind-address = “:2003”
protocol = “tcp”
consistency-level = “one”
These next lines control how batching works. You should have this enabled
otherwise you could get dropped metrics or poor performance. Batching
will buffer points in memory if you have many coming in.
Flush if this many points get buffered
batch-size = 5000
number of batches that may be pending in memory
batch-pending = 10
Flush at least this often even if we haven’t hit buffer limit
batch-timeout = “1s”
UDP Read buffer size, 0 means OS default. UDP listener will fail if set above OS max.
udp-read-buffer = 0
This string joins multiple matching ‘measurement’ values providing more control over the final measurement name.
separator = “.”
Default tags that will be added to all metrics. These can be overridden at the template level
or by tags extracted from metric
tags = [“region=us-east”, “zone=1c”]
Each template line requires a template pattern. It can have an optional
filter before the template and separated by spaces. It can also have optional extra
tags following the template. Multiple tags should be separated by commas and no spaces
similar to the line protocol format. There can be only one default template.
templates = [
“*.app env.service.resource.measurement”,
# Default template
“server.*”,
[collectd]
Controls one or many listeners for collectd data.
[[collectd]]
enabled = false
bind-address = “:25826”
database = “collectd”
The collectd service supports either scanning a directory for multiple types
db files, or specifying a single db file.
typesdb = “/usr/local/share/collectd”
security-level = “none”
auth-file = “/etc/collectd/auth_file”
batch-size = 5000
Number of batches that may be pending in memory
batch-pending = 10
batch-timeout = “10s”
read-buffer = 0
Multi-value plugins can be handled two ways.
“split” will parse and store the multi-value plugin data into separate measurements
“join” will parse and store the multi-value plugin as a single multi-value measurement.
“split” is the default behavior for backward compatability with previous versions of influxdb.
parse-multivalue-plugin = “split”
[opentsdb]
Controls one or many listeners for OpenTSDB data.
[[opentsdb]]
enabled = false
bind-address = “:4242”
database = “opentsdb”
tls-enabled = false
certificate= “/etc/ssl/influxdb.pem”
Log an error for every malformed point.
log-point-errors = true
otherwise you could get dropped metrics or poor performance. Only points
metrics received over the telnet protocol undergo batching.
batch-size = 1000
batch-pending = 5
[[udp]]
Controls the listeners for InfluxDB line protocol data via UDP.
[[udp]]
enabled = false
bind-address = “:8089”
database = “udp”
InfluxDB precision for timestamps on received points (“” or “n”, “u”, “ms”, “s”, “m”, “h”)
precision = “”
batch-size = 5000
batch-pending = 10
Will flush at least this often even if we haven’t hit buffer limit
read-buffer = 0
[continuous_queries]
Controls how continuous queries are run within InfluxDB.
Determines whether the continuous query service is enabled.
enabled = true
Controls whether queries are logged when executed by the CQ service.
log-enabled = true
Controls whether queries are logged to the self-monitoring data store.
query-stats-enabled = false
interval for how often continuous queries will be checked if they need to run
run-interval = “1s”
[tls]
Global configuration settings for TLS in InfluxDB.
[tls]
for a list of available ciphers, which depends on the version of Go (use the query
SHOW DIAGNOSTICS to see the version of Go used to build InfluxDB). If not specified, uses
the default settings from Go’s crypto/tls package.
ciphers = [
“TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305”,
“TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256”,
Minimum version of the tls protocol that will be negotiated. If not specified, uses the
min-version = “tls1.2”
Maximum version of the tls protocol that will be negotiated. If not specified, uses the
max-version = “tls1.2”
MarcV
February 27, 2019, 2:00pm
11
Hi I reduced your post to the non-default parameters ,
I don’t know if someone else sees something wrong in it
[meta]
[data]
[http]
max-body-size = 0
