I have a Telegraf node that ingests a newline delimited JSON file and emits to influxdb.
I have the following configuration for inputs.tail:
[[inputs.tail]]
files = ["./*.txt"]
from_beginning = true
json_time_key = "time"
json_time_format = "2006-01-02T15:04:05Z07:00"
json_name_key = "foo"
tag_keys = ["foo","bar","stooge"]
data_format = "json"
This input configuration works as expected. Telegraf ingests a 2GB file of ~3M JSON data points without issue.
I then decided to get fancy and emit to a separate DB per stooge.
[[outputs.influxdb]]
urls = ["http://127.0.0.1:8086"]
database = "MOE"
[outputs.influxdb.tagpass]
stooge = ["MOE"]
database = "LARRY"
stooge = ["LARRY"]
database = "CURLEY"
stooge = ["CURLEY"]
This works as expected, except that I see some errors.
2019-04-24T18:52:34Z E! [agent] Error writing to output [influxdb]: could not write any address
2019-04-24T18:52:36Z E! [outputs.influxdb] when writing to [http://127.0.0.1:8086]: Post http://127.0.0.1:8086/write?db=MOE: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2019-04-24T18:52:39Z E! [outputs.influxdb] when writing to [http://127.0.0.1:8086]: Post http://127.0.0.1:8086/write?db=LARRY: net/http: request canceled (Client.Timeout exceeded while awaiting headers)
2019-04-24T18:52:39Z D! [outputs.influxdb] buffer fullness: 10000 / 10000 metrics.
2019-04-24T18:52:39Z E! [agent] Error writing to output [influxdb]: could not write any address
2019-04-24T18:55:31Z W! [agent] output "influxdb" did not complete within its flush interval
I have two questions
- Are these timeouts of any concern? Or will telegraf re-try to emit the data until it receives a successful WRITE ACK from InfluxDB?
- Should I tune the parameters, e.g. decrease the batch size, increase the buffer size, and increase the timeouts or is this a bad idea?
