I am writing data to influxdb using the node-influx library.
I am using influx.writePoints to do the writes as explained here,
https://node-influx.github.io/manual/tutorial.html
The only tweak I made is insert in batches. The batchsize is set to 10000.
It writes about 500,000 records and then I start seeing this error following which there are no more writes. It looks like a dns issue but I am running it inside a docker container on ubuntu 18.04 host.
Error: getaddrinfo EAGAIN influxdb influxdb:8086 |at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:56:26)
I have the logging level set to debug but I am not seeing any other errors.
I am able to write using curl even after the error
Update
I am using a worker container to do the writes and the error is happening on it. If I restart this container after I get the error, the writes start happening again for another 500,000 points and then I get the same error.
It could be a connection issue from the worker to influx
Here is the output of
curl http://localhost:8086/debug/vars | jq
"httpd::8086": {
"name": "httpd",
"tags": {
"bind": ":8086"
"values": {
"authFail": 0,
"clientError": 0,
"fluxQueryReq": 0,
"fluxQueryReqDurationNs": 0,
"pingReq": 0,
"pointsWrittenDropped": 0,
"pointsWrittenFail": 0,
"pointsWrittenOK": 500000,
"promReadReq": 0,
"promWriteReq": 0,
"queryReq": 0,
"queryReqDurationNs": 0,
"queryRespBytes": 0,
"recoveredPanics": 0,
"req": 52,
"reqActive": 1,
"reqDurationNs": 2543066084,
"serverError": 0,
"statusReq": 0,
"writeReq": 50,
"writeReqActive": 0,
"writeReqBytes": 61858063,
"writeReqDurationNs": 2535763137
As you can see I am not seeing any failures here. It looks like I am running into some limit here, I have already upped the ulimit on the host.
This is my influxdb.conf
reporting-disabled = true
[meta]
dir = "/var/lib/influxdb/meta"
retention-autocreate = false
logging-enabled = true
[logging]
format = "auto"
level = "debug"
[data]
engine = "tsm1"
dir = "/var/lib/influxdb/data"
wal-dir = "/var/lib/influxdb/wal"
wal-fsync-delay = "0ms"
index-version = "inmem"
wal-logging-enabled = true
query-log-enabled = true
cache-max-memory-size = "1g"
cache-snapshot-memory-size = "25m"
cache-snapshot-write-cold-duration = "10m"
compact-full-write-cold-duration = "4h"
max-concurrent-compactions = 0
compact-throughput = "48m"
max-points-per-block = 0
max-series-per-database = 1000000
trace-logging-enabled = false
[coordinator]
write-timeout = "30s"
max-concurrent-queries = 0
query-timeout = "0s"
log-queries-after = "0s"
max-select-point = 0
max-select-series = 0
max-select-buckets = 0
[retention]
enabled = true
check-interval = "30m0s"
[shard-precreation]
enabled = true
check-interval = "10m0s"
advance-period = "30m0s"
[monitor]
store-enabled = true
store-database = "_internal"
store-interval = "10s"
[http]
enabled = true
bind-address = ":8086"
auth-enabled = false
log-enabled = true
max-concurrent-write-limit = 0
max-enqueued-write-limit = 0
enqueued-write-timeout = 0
[continuous_queries]
enabled = false
log-enabled = true
run-interval = "10s"
