I’m using the latest influx version 1.7.10. I’m having issues with my influx systems that they’re taking up ! 98% memory allocated. I’ve four instances running and 2 of the instances are taking up almost 100% of the assigned RAM and the other instance which receives a big chunk of data is only peaked out sometimes otherwise it was always well below 60% . Could anyone help in troubleshooting the issue why do I see the full usage of memory?
Thanks,
NK
