Background: I’m running influxdb in docker on a Raspberry Pi 3 Model B Rev 1.2 with 1Gb ram for tracking some home automation variables. My database backup is 50-100MB and I write 5-6 entries per minute have in total ~10 series, and I query the database once or twice a week.
I recently decided to jump from influxdb version 1.7 to 2.6. Initial testing on my laptop went fine, but when I tried to deploy to the raspberry I noticed that memory consumption had jumped from ~50MB reserved memory to ~300MB reserved memory which didn’t fit with my other containers. I tried tuning all memory related config options, but could not make any significant dents into the memory usage. These were my final settings:
- INFLUXD_HTTP_READ_TIMEOUT=20s
- INFLUXD_HTTP_WRITE_TIMEOUT=20s
- INFLUXD_METRICS_DISABLED=true
- INFLUXD_PPROF_DISABLED=true
- INFLUXDB_REPORTING_DISABLED=true
- INFLUXD_QUERY_INITIAL_MEMORY_BYTES=262144
- INFLUXD_QUERY_MEMORY_BYTES=5242880
- INFLUXD_QUERY_QUEUE_SIZE=3
- INFLUXD_STORAGE_CACHE_MAX_MEMORY_SIZE=5242880
- INFLUXD_STORAGE_CACHE_SNAPSHOT_MEMORY_SIZE=5242880
- INFLUXD_STORAGE_MAX_CONCURRENT_COMPACTIONS=1
- INFLUXD_STORAGE_MAX_INDEX_LOG_FILE_SIZE=262144
- INFLUXD_STORAGE_SERIES_FILE_MAX_CONCURRENT_SNAPSHOT_COMPACTIONS=1
- INFLUXD_STORAGE_SERIES_ID_SET_CACHE_SIZE=0
Restricting the amount of available memory via docker just terminated influxdb.
I then went back to influxdb 1.7 and tried turning on INFLUXDB_DATA_INDEX_VERSION=tsi1 and again the memory jumped to around 300MB.
I would like to use influxdb 2, since I think the API is much nicer, so I’m wondering both why tsi1 is using more memory, and also if there is any way to reduce memory usage with tsi1 so I can switch to influxdb2?
