I have DB with 7 logical db’s inside (36G on disk total, cardinality from 10k to 312k), running in Docker 1.7.9-alpine. It was working fine with 4G RAM AWS server until I decided to migrate the index engine from tsm(inmem) to tsi (with influx_inspect buildtsi). After migration, it just won’t start with that amount of memory. Crashes after 2-3 minutes with OOM. I have changed instance type to 16G RAM and limited docker container to 8G. It started but works for a few hours and then reboot with OOM. I tried to remove limits so it takes 13G of RAM and works fine. Swap is disabled.
So I’m trying to find an answer for the following questions: Why tsm (inmem) index was ok with 4 gigs of RAM but tsi (which is RAM optimized), doesn’t work even with double amount of that memory?
Second: why influx doesn’t have an option to limit memory usage even if this affects performance?
I tried to recreate tsi index multiple times even with decreased max-index-log-file-size
Shard duration is the default - 7 days and RP is forever
Here are some of my db settings:
[data]
index-version = “tsi1”
cache-max-memory-size = “1g”
cache-snapshot-memory-size = 26214400
compact-throughput = 50331648
compact-throughput-burst = 50331648
max-series-per-database = 1000000
max-values-per-tag = 100000
max-concurrent-compactions = 0
max-index-log-file-size = 131072
Similar problem described here TSM-based vs. TSI-based memory usage
I will appreciate any help, thanks!
