High Memory Usage Problem in influx version - 1.2.2
Hi
version : 1.2.2
The number of fields : About 8000
I have hard time because of High Memory Usage Problem
Currently, the Influx process is using 40 g of 64 g memory.
Also, this momory usage is rising continuously.
About reason on such a subject, I guess because i run this query - “select (*) every field from …”
After running the query, influx client is dead.
These Things can affect high memory usage problem?
plz answer me.
thanks.
Hi Wook welcome ,
do you have plans to upgrade , the most recent version is 1.7.6 ,
is there a time limit on your query , I mean for example "where time > now() -1d "
what is the output of
influxd config|grep -i index
best regards ,
Hi ,
I am also facing this issue sometimes.
and the output of influxd config | grep -i index is
Merging with configuration at: /etc/influxdb/influxdb.conf
index-version = “inmem”
Hi @Gobiviswa ,
this may be helpfull …
Starting with the InfluxDB 1.6 release, enabling Time Series Index (TSI) is recommended for all customers. To learn more about TSI, see:
* [Time Series Index (TSI) overview](https://docs.influxdata.com/influxdb/v1.7/concepts/time-series-index/)
* [Time Series Index (TSI) details](https://docs.influxdata.com/influxdb/v1.7/concepts/tsi-details/)
The upgrade steps below guide you in upgrading InfluxDB OSS and InfluxDB Enterprise, enabling TSI functionality.
> ***Note:***  For the InfluxDB 1.7 release, the default continues to use TSM-based shards as in earlier versions, with in-memory indexes.
