Riffing on this a little bit: I really wish I could limit the amount of memory used by a query per se. I know how much memory my machine has, and about how many concurrent queries I’d like to support, so I could set a memory limit that way. With max-select-series and max-select-points, I don’t really know how many bytes a point might be or how many bytes a series might be, so I’m stabbing in the dark to set those parameters.
Here’s a specific question: If a user, say, selects a lot of series over a long time period, then sure, I’d expect that to take a lot of memory. But if they do the same query over a lot of series with a very short time period, I’d expect that to take a lot less memory. I’m assuming that it doesn’t just page in the entire series when the series is touched, but rather it pages-in some small chunk based on the time parameter. Given that intuition, it seems like it doesn’t make sense to limit max-select-series, only max-select-points. Or am I wrong—is there some large amount of minimum memory footprint per series touched?
