Why is there any ERR: 401
just installed v2.8 but probably I did not understood the use of influx. Can anybody see my problem:
jv@JamesWebb:~$ ssh jv@10.10.20.164
jv@10.10.20.164's password:
Permission denied, please try again.
Linux raspberry 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri May 29 17:36:08 2026 from 10.10.20.158
jv@raspberry:~ $ influx v1 shell
InfluxQL Shell dev
Connected to InfluxDB OSS v2.8.0
> create database test
ERR: 401 Unauthorized: unauthorized access
> show databases
> exit
Goodbye!
jv@raspberry:~ $
Make sure you’re following the setup steps in the documentation for InfluxDB v2! You’ll need to create an API token to authenticate with before you can start writing/creating things.
SSH login only authenticates you to the Raspberry Pi; InfluxDB has its own authentication. For the v1 shell, pass an InfluxDB API token as the password (and a username if prompted). Also, InfluxDB 2 uses buckets rather than CREATE DATABASE; create the bucket in the UI or with the v2 CLI.
