I am configuring the elasticsearch input for telegraf (version 1.25.0), and running into an issue where telegraf is continually logging
[inputs.elasticsearch] Error in plugin: elasticsearch: API responded with status-code 401, expected 200
The configuration for the elasticsearch input plugin looks like this:
# Read stats from one or more Elasticsearch servers or clusters
[[inputs.elasticsearch]]
## specify a list of one or more Elasticsearch servers
# you can add username and password to your url to use basic authentication:
# servers = ["http://user:pass@localhost:9200"]
servers = ["https://elastic.server:9200"]
## Timeout for HTTP requests to the elastic search server(s)
http_timeout = "5s"
## When local is true (the default), the node will read only its own stats.
## Set local to false when you want to read the node stats from all nodes
## of the cluster.
local = false
## Set cluster_health to true when you want to also obtain cluster health stats
cluster_health = true
## Adjust cluster_health_level when you want to also obtain detailed health stats
## The options are
## - indices (default)
## - cluster
# cluster_health_level = "indices"
## Set cluster_stats to true when you want to also obtain cluster stats from the
## Master node.
cluster_stats = true
## node_stats is a list of sub-stats that you want to have gathered. Valid options
## are "indices", "os", "process", "jvm", "thread_pool", "fs", "transport", "http",
## "breaker". Per default, all stats are gathered.
# node_stats = ["jvm", "http"]
## Optional TLS Config
tls_ca = "/etc/telegraf/ca.crt"
tls_cert = "/etc/telegraf/clientcert.crt"
tls_key = "/etc/telegraf/clientcert.key"
## Use TLS but skip chain & host verification
username = "telegraf_user"
password = "telegraf_user_password"
I have also attempted putting the user/password information in the url configured in the servers setting.
I have verified that I can manually connect to elasticsearch using the provider user info and certificates (via curl).
Is there a way for me to get insight into what exact calls telegraf is making so I can debug this a little bit better?
The curl command I am trying is:
curl --cacert /etc/telegraf/ca.crt --cert /etc/telegraf/clientcert.crt --key /etc/telegraf/clientcert.key https://telegraf_user:telefraf_user_password@elkdevn1.dev.oati.local:9200/_nodes/_local/name
To which I get a response like:
{"_nodes":{"total":1,"successful":1,"failed":0},"cluster_name":"elkcluster","nodes":{"nodeitentifier":{"name":"elastic.server","transport_address":"10.100.2.128:9300","host":"10.100.2.128","ip":"10.100.2.128","version":"7.16.2","build_flavor":"default","build_type":"rpm","build_hash":"2b937c44140b6559905130a8650c64dbd0879cfb","roles":["data","ingest","master"],"attributes":{"xpack.installed":"true","transform.node":"false"}}}}
